  4. Homograph s. Lösung für das IPhone
44 Posts 13 Posters 26.4k Views 4 Watching
    @Tom-Johann, funny detail: my Google Maps showed the EXACT same problem concerning the loudness of the voice... If not playing music, you just turn up the volume of the radio/headset, but when playing music that is of course no option. Then if an instruction is given, the music ducks, but the voice is still not loud enough to overcome the music. GMaps showed the exact same thing during my holiday (I used it in my car, BT connected to my car radio).
    The Homograph error is already established to be a problem in some IOS versions. The old app (and many other nav apps) has it's own internal speech synthesis. The new app relies on the OS for that. I am not sure whether the voice instruction itself originates from the app or from the HERE platform. It likely contains some intonation data that gets misinterpreted by the IOS speech synthesis. The MRA devs or the HERE devs could probably strip those, but that would mean loss of voice quality for everyone. Having an own embedded speech synthesis would likely be more flexible, but probably not easy to combine with the HERE platform. It is a chosen direction that is likely not easy to change. Google around, or search for earlier messages in this forum. There seem to be IOS voices that do not show (or speak) this problem.
    As written somewhere from me, the TT GoRide-App had the same problem with Homegraph and they fixed it internal (without an Apple update).
    But hopefully Apple will fix it with iOS 17.
      @Peter-Schiefer, I think you need to realise it is not my software 😉 I have no affiliation with MyRoute-app.
      Gestern nach dem Update auf 4.04 wo eine neu Stimme angekündigt wurde gehofft das Homograph Problem sei gelöst.
      I am not aware of a new voice, but yes improvements have been made to how voice guidance is given. Not on the voice itself, that's an OS thing. I am not denying something could perhaps be done by MRA to prevent the homograph problem, but you need to realize it is ultimately an IOS bug. It is entirely possible that other companies, with undoubtedly a larger dev team, have found a workaround for it. I heard recently that also TomTom has the same problem. Why not ask the bug-owner to solve the bug? In the meantime, what I understood from other users using IOS, the problem is solved by choosing a different voice in your IOS settings. You will find details by searching in this forum.
      Immer wieder meldet MyRoute App ohne dass es geöffnet ist, einen Absturz auf dem iPhone?
      I have not heard this before. Best thing to do is to send some crashreports to the dev team, along with a description of the problem (at what time it happens and under what circumstances).
      • Jörgen
        Das Update auf iOS 17 soll im September kommen und das Homograph Problem beseitigen. Ein Wechsel zu einer anderen Stimme ändert nichts. Also warten...
        Oder die Jungs machen es wie der andere Holländische Mitbewerber und ändern es in der App.
        • Jörgen Jörgen
          @Jörgen : Danke für die Info ❗️
          • Hubert Thoring
            Das iOS 17.0 steht jetzt zur Verfügung
            Jörgen 1 Reply Last reply
              @Hubert-Thoring Und schon probiert?
              Mopetenpit Hubert Thoring 2 Replies Last reply
              • Jörgen Jörgen
                Mopetenpit
                Mopetenpit
                Mopetenpit
                @Jörgen ja, jetzt funktioniert es!!😁
                • Mopetenpit Mopetenpit
                  @Mopetenpit Hurra, Hurra der Homograph ist tot. 😁
                  Aber nicht zu früh freuen, er war auch mal in einer früheren Version weg und kam mit einem weiteren Update zurück.
                  Aber gut zu wissen, jetzt muss nur noch iOS 17 keine Fehler enthalten, dann geht es entlich mit Ton weiter. 😉
                  • Tom Johann
                    Tom Johann
                    Tom Johann
                    Soeben kam das Update von Apple auf iOS 17.0 auf mein iPhone 12.
                    Das Homograph-Problem hat sich erledigt!! Das ist wirklich TOP!
                    Danke für die Unterstützung und die vielen Erklärungen 😉
                    • Jörgen Jörgen
                      @Jörgen :
                      @Drabslab
                      @Manfred-Hauser-0
                      @Matt
                      @Mopetenpit
                      @Nick-Carthew
                      @Peter-Schiefer
                      @Rob-Verhoeff
                      Guten Morgen in die Runde, ja gestern ausprobiert, über 240km und das Thema Homograph ist jetzt nach dem iOS Update auf 17.0 erledigt.
                      Gleichzeitig hatte ich heute das Gefühl das die Audioqualität im Zusammenspiel mit den gekoppelten Geräten wie Handy iPhone Xr, Sena S3, BMW Cradel und BMW TFT jetzt etwas klarer und deutlicher ist, vielleicht weil MyRoute-App ja jetzt auch einen anderen Audiokanal nutze seit dem letzten Update.
                      Danke an alle die daran aktiv mitgearbeitet haben !!
                      VG 👋
                      • Jörgen
                        Mir wird auf meinem iPhone X noch kein Update angeboten. 😢
                        Hubert Thoring Mopetenpit 2 Replies Last reply
                        • Jörgen Jörgen
                          @Jörgen : iPhone suchen lassen
                          Unter …. / Einstellungen/ Allgemein / Softwareupdate / …
                          • Jörgen Jörgen
                            Mopetenpit
                            Mopetenpit
                            Mopetenpit
                            @Jörgen Ich glaube, da musst du mindestens das Model "XS" für iOS 17 haben...
                            Hubert Thoring Jörgen 2 Replies Last reply
                              #38
                              @Mopetenpit : ich habe das iPhone Xr (war mal günstiger als das X 😉) damit habe ich auch das Update bekommen 👋
                              @Jörgen : du scheinst jetzt Pech zu haben schau mal was unten steht ..
                              Mopetenpit 1 Reply Last reply
                                Mopetenpit
                                Mopetenpit
                                Mopetenpit
                                @Hubert-Thoring ja, das ist richtig. Das "XR" kam auch nach dem "X" raus. Das "XR" und "XS" kamen 2018 auf den Markt, das "X" in 2017.
                                  Watch out with spamming that letter.
                                  Musk might come after you 😉
                                    Mopetenpit
                                    Mopetenpit
                                    Mopetenpit
                                    Auf diesen iPhones lässt sich iOS 17 installieren:
                                    iPhone 15-Generation (mit dem Release 2023)
                                    iPhone 14 (Release 2022)
                                    iPhone 14 Pro (Release 2022)
                                    iPhone 14 Pro Max (Release 2022)
                                    iPhone SE 3 (Release 2022)
                                    iPhone 13 (Release 2021)
                                    iPhone 13 Pro (Release 2021)
                                    iPhone 13 Pro Max (Release 2021)
                                    iPhone 13 Mini (Release 2021)
                                    iPhone 12 (Release 2020)
                                    iPhone 12 Pro (Release 2020)
                                    iPhone 12 Pro Max (Release 2020)
                                    iPhone 12 Mini (Release 2020)
                                    iPhone SE 2 (Release 2020)
                                    iPhone 11 (Release 2019)
                                    iPhone 11 Pro (Release 2019)
                                    iPhone 11 Pro Max (Release 2019)
                                    iPhone Xs (Release 2018)
                                    iPhone Xs Max (Release 2018)
                                    iPhone Xr (Release 2018)
                                      @Mopetenpit said in Homograph s. Lösung für das IPhone:
                                      Sieht tatsächlich so aus, als wenn das X kein Update mehr bekommt. So ein Shit muss ich mit dem blöden Homograph weiterleben, kacke!
                                      Mir geht es dabei ja nur um diesen Problem Buck in iOS.
                                        Soeben hat Apple 17.0.1 veröffentlicht. Fehlerbehebung und Sicherheitsupdates.
                                        Kindly regards
                                        Reinhard
                                        Montana 700i and Mac
                                        • Jörgen
                                          @Peter-Schiefer said in Homograph s. Lösung für das IPhone:
                                          Gerade noch nachgelesen, das X ist aus den Update zu IOS17 raus.
                                          Da ich auf meinem iPhone 13 das 17 installiert hatte, gestern extra mal eine Route gefahren. Das Homograph Problem ist weg. Jetzt nur noch sowas wie Routenpunkt überspringen oder die eine oder andere notwendige Funktion im Routing ins CarPlay Menü und man könnte sich damit immer mehr anfreunden. Allerdings derbe Routenfehler, berichte dazu separat.
                                          Meinst du Routenpunkt überspringen in Carplay oder generell?
                                          Mopetenpit
                                          Mopetenpit
                                          Tom Johann
                                          Tom Johann
                                          Manfred Hauser 0
                                          Manfred Hauser 0
                                          Matt
                                          Matt
                                          • Hide warnings on the map
                                          • Testroute segmenten
                                          • Map Layers
                                            Martin White
                                            Martin White
                                            Michael 2v
                                            Michael 2v
                                          • Bollard trouble
                                          • Library: Folders at the Top of the Menu
