  4. Still having issues with the volume control on iPhone
8 Posts 6 Posters 1.9k Views 2 Watching
  • UltraStar Offline
    UltraStar Offline
    UltraStar
    wrote on last edited by UltraStar
    iPhone 11P, iOS 16.6.1; MRA v.4.0.4 - 216. I do not know if this was reported lately. I am still having issues with the volume. I have volume set in the MRA at loud.
    When I use the navigation and listen to the music at the same time, I have to set the volume on the radio or the helmet headset high to hear the voice announcements. If I set the volume too low-at the level that I can enjoy my music without getting deaf-I cannot clearly hear the voice announcements.
    I just came back from 1600 miles trip in the car. I have paused the music at the beginning of the ride, and I could not hear the voice announcements at all. I had to crank up the volume on the radio to 3/4 (unbelievably loud for music) to hear the voice announcements clearly. The problem with this setting is that, every time I turn off the car and come back later on, the music replay starts automatically and the radio blasts out almost giving me a heart attack.
    It would be great if we could adjust the volume of the voice announcements relative to the music volume (not just three preset levels.) This way user could set up his own level of the voice announcements, and every time the music plays louder, the voice announcements would be louder, and opposite.
    Right now, I have to play music louder than I would like just to hear the voice announcements.
    Also, in the previous version of MRA, I rode about 5700 miles, and most of the times I was missing the beginning of the announcement; more or less, usually more. It was very confusing until I got used to it. In example: if the turn was approaching and it was 3/4 of a mile to it, I got announcement: "...turn right" instead of "In 3/4 of a mile, turn right."
    That scared the living stuff out of me, especially in a city traffic.
    • Lenz Offline
      Lenz Offline
      Lenz
      Same Problem with Android. I writed it in testflight …..
      • Mike Whitwam Offline
        Mike Whitwam
        Same problem, Sena headset on max volume and volume setting in app set to loudest setting and still quiet voice instructions which are totaly unclear at higher (legal) speeds.
        I also find that there is very little or no difference between the middle setting and highest setting in the app volume choices.
        • UltraStar UltraStar
          @UltraStar said in Still having issues with the volume control on iPhone:
          It has been reported a lot in the past. It has not been reported for a while anymore. Since some updates the situations seems to have greatly improved. I was under the impression that in the current IOS version the volume could even be set independently. Up the volume while the app speaks. Am I mistaken?
          On Android the problem on both my phones was solved with the same update, Dev however told me there was not done any work on it 🤣 Ever since I have not seen any messages about the issues anymore, Until now... 😉
          Rob Verhoeff UltraStar 2 Replies Last reply
            Rob Verhoeff Offline
            @Con-Hennekens said in Still having issues with the volume control on iPhone:
            Not possible on iOS16. Since yesterday we have iOS17. Not installed yet, but I think this update won't repair that either.
            • Albert van den Elsen Offline
              I have the same problem.
              Sena,Garmin XT and iPhone12
              iPhone 15,
              Carpuride W702 Pro
              Sena 20S EVO headset
              Harley Davidson Road King M8
                Mike Whitwam
                Just an update to say my issue has now been sorted with voice volume level (fault found with headset now sorted).
                  UltraStar Offline
                  UltraStar Offline
                  UltraStar
                  @Con-Hennekens It got better a while ago. Before then, it was really bad; could not hear anything and the announcements were badly cut off (at the beginning and the end.)
                  Now, the volume is little better, with the stress on "Little bit."
                  I was hoping that the volume can be set separately, and once done, they would be adjusted together in relation to each other settings (for music and announcements,) but its not a case. You cannot adjust the volume separately.
                  Also, the announcements cut at the beginning (most often) and truncated (rarely) are really confusing.
                  Lenz
                  Lenz
                  UltraStar
                  UltraStar
                  Mike Whitwam
                  Mike Whitwam
                  • Welke instelling
                    996
                    Thomas Schäfer
                    Thomas Schäfer
                  • opslaan naar plantomtom
                    chris 18
                    chris 18
                    430
                  • Seizoen sluitingen wegen
                    PAT62
                    PAT62
                  • App loopt vast
                  • I can't see Road Closures
                  • Rejoining routes
