  4. Length of 'text to speech' function
22 Posts 7 Posters 6.5k Views 2 Watching
  • motorwimtimmerman.eu Offline
    The new 'text to speech' function is great. On a VIA point, you change the Text on the route point in anything you want. Like: the next point gives you a great view on the lake'. Text could be anything but shall not contain numbers. So no 7 but if you want to have it in, make it 'seven'.
    However, it does not speak out the whole text I have entered. Probably it is too long.
    Is there a restriction on the text length? And if so, how long can e sentence be.
    Hans van de Ven MR.MRA Con Hennekens 2 Replies Last reply
    • motorwimtimmerman.eu motorwimtimmerman.eu
      @WimTim
      512 characters
        @WimTim, You have the option of the WP name and the WP note. Those are two different things that both get read underway. If you only change the name it will NOT be read if there is a figure in it. It WILL get read of there is a figure in it AND there is a note present. If, like @Hans-van-de-Ven-MRA-Master says, the name can be up to 512 characters, I suppose the note is at least equally long. But hey, if you put that much text in, you will probably miss the next turn (or the text gets interrupted, don't know). ๐Ÿ˜‰
          @Con-Hennekens and @WimTim
          512 characters is the note. The name is much shorter
            Rob Verhoeff Offline
            @Hans-van-de-Ven-MRA-Master @Con-Hennekens I tried to fill the name of the waypoint. Stopped at 100 charchters... I wonder how long one can go on putting text in that field!
            When putting spaces in between you can go as far as 101 characters...
            ๐Ÿ’ป Routelab on MacBook Air & iMac (Tahoe & Ventura)
            Nick Carthew Jack van Tilburg 2 Replies Last reply
              Nick Carthew Offline
              @Rob-Verhoeff But they will not be seen in the app.
                Jack van Tilburg Offline
                Jack van Tilburg
                @Rob-Verhoeff said in Length of 'text to speech' function:
                As long as you don't go to Llanfairpwllgwyngyllgogerychwyrndrobwllllantysiliogogogoch, that's not that important, is it? ๐Ÿคฃ
                Rob Verhoeff Con Hennekens 2 Replies Last reply
                  @Nick-Carthew that's right.
                    @Jack-van-Tilburg ๐Ÿ˜
                      Actually it isnโ€™t ๐Ÿ˜… I have just tested this and the title has rolling text like the note.
                      Corjan Meijerink Rob Verhoeff 2 Replies Last reply
                        Corjan Meijerink Online
                        @Nick-Carthew Correct! When there is no (scrolling) description / note, the title will be scrolling if required by the length of that text ๐Ÿ™‚
                          @Nick-Carthew said in Length of 'text to speech' function:
                          Check... Indeed the textlenght scrolls by to a max of 101 charchters. I moved the first waypoint before checking. Then your given name is changed back to the original name of the waypoint.
                          Nick Carthew 3 Replies Last reply
                            @Rob-Verhoeff I titled RP1 123456789 123456789 123456789
                            I canโ€™t share the video in the forum so I added it to YouTube: https://youtube.com/shorts/PfBJa6n-x9s?si=rxDl0wAEU_1IQqa8
                              @Rob-Verhoeff Hereโ€™s the title.
                                @Nick-Carthew I did it the same way, then it show to a max of 101 characters.
                                  @Rob-Verhoeff I added 3 sets of 123456789 for the title but looking at my video it appears that only 2 sets are scrolling. There is a large gap after 2 sets.
                                    #17
                                    @Jack-van-Tilburg said in Length of 'text to speech' function:
                                    Thanks... Now I want to hear the navigation voice pronounce that... ๐Ÿ˜‰
                                    • Con Hennekens Offline
                                      It seems there was not much on TV yesterday evening ๐Ÿ˜‰
                                        Jack van Tilburg
                                        #19
                                        @Con-Hennekens said in Length of 'text to speech' function:
                                        But only when you. are in that region of course. Driving via Llangollen and Betws-Y-Coed to the Yr Wyddfa ๐Ÿ˜
                                          @Jack-van-Tilburg Using the Wales 360 RouteXpert route is a nice way to pass Llanfairpwllgwyngyllgogerychwyrndrobwllllantysilio gogogoch ๐Ÿ˜Š
                                          View 'Wales 360 Bala Caernarfon Holyhead Llandudno' in MyRoute-app! https://www.myrouteapp.com/route/open/7933523
                                          Jack van Tilburg
                                          Jack van Tilburg
                                          • HERE maps updates
                                            12.1k
                                            Alfred Schrittwieser
                                            1.4k
                                            Bruno 7
                                            Bruno 7
                                            Theo Lammerts
                                            Theo Lammerts
                                            680
