  4. Trying to get a route from MRA onto my Zumo XT, has no waypoints
8 Posts 5 Posters 2.1k Views 2 Watching
  • Chris Smithundefined Offline
    Chris Smith
    wrote on last edited by Chris Smith
    It's been a while since I've done this. (Mice ate my motorcycle wiring harness). I've made many routes and put them on an old Zumo 220, long dead and my current GPS, a Zumo XT. I've done it successfully before.
    But now when export it via the Connector, and import it via Trip PIanner app on he Zumo XT itself, I only get a start and end waypoint on the GPS. I need the waypoints, because we're stopping for lunch, then going to an aircraft museum, then a motel. Right now, I can only see the starting location near my house and the end location, the motel.
    I can't recall the the terminology, but there used to be 2 types, beginning and end were one type, and anything in the middle was a different type.
    I tried Garmin Zumo XT 1.2 and also GPX 1.1, the result was the same, no middle waypoints. What's happening here? See attached file. You can see my export options but also see Waypoint #2 (lunch), Waypoint #3 (the Dayton OH Air Force Museum and the endpoint/Waypoint #4, the motel. Yet when I import the gpx via the Trip Planner interface on the Garmin, I only see start and end. Why?
    This first day is quite simple, only 4 points total, other days in curvy road areas have 20 or more waypoints. Help!![ Thank you!
    MRA_BaBv2_issue.png](/assets/uploads/files/1694725213343-mra_babv2_issue.png)
    Nick Carthewundefined Hans van de Ven MR.MRAundefined 2 Replies Last reply
    • Chris Smithundefined Chris Smith
      Nick Carthewundefined Online
      @Chris-Smith With GPX 1.2 you only see Via points (hand shape) so add Via points for your stops.
      Chris Smithundefined 1 Reply Last reply
        Jack van Tilburg
        @Chris-Smith
        Does this help you?
        https://forum.myrouteapp.com/post/34562
          Chris Smith
          @Nick-Carthew OK dumb question. Will it still give you turn by turn directions, despite the fact that the waypoints that mark where to turn at don't show on the screen?
            @Chris-Smith
            Does this help you?
            Chris Smith
            @Jack-van-Tilburg It tells me what I already know, how to load them.
            The problem was I couldn't figure out where all the waypoints went. So when I loaded the routes as GPX 1.1, the waypoints showed.
            But I did notice on 2 of the days, the routes I made on the web were not the same as the routes loaded into the GPS, the GPS found a 'better way', a more direct route. It bypassed. I added another waypoint in MRA to make the GPS run the same route as MRA.
            Travellexxieundefined 1 Reply Last reply
              @Chris-Smith
              You have to import the route into the XT. Go to journey in the XT and choos Import via the menu
                @Chris-Smith said in Trying to get a route from MRA onto my Zumo XT, has no waypoints:
                Yes it will.
                  Travellexxieundefined Offline
                  @Chris-Smith that can be correct. In the 1.1 Version you see the shapingpoints (not waypoints), but the XT calculate its own route. So, if you have only a few shapingpoints in your route, the deviation might be a lot more, as if you force the XT the calculate the route by more shapingpoints. That means: go back to your routeplanning and add more shapingpoints. When you transfer the new route, it will be all right.
                  If you transfer the 1.2 version, you only have to set the re-calculation in "off" position, set back, reLex and ride your route 😊
                  MRA Lifetime Gold
                  Jack van Tilburg
                  Chris Smith
                  • Choice for starting point of a route
                    354
                  • Veekeersinfo en omleiden
                  • Skipping a Via point...
                    343
                  • Web App isn’t stable
                    Aiello antoninoundefined
                    Richard 18undefined
                    Richard 18
                  • Library sync error
                    Albert van den Elsenundefined
                  • how can I make Next speak the waypoints and notes to me?
                    supergundefined
                  • CarPlay route selection functionality
