  4. Has the Motorbike problem been fixed in 4.0.3???
59 Posts 11 Posters 37.3k Views 5 Watching
    @Nick-Carthew Hi and thanks a lot for testing however I just checked this and I have backrough app refresh on for the myroureapp.
    maybe the problem or difference is that you had your phone mounted and not in your jacket pocket? maybe because it was mounted it was nor completely locked or so?
    I am just guessing but it must be possible somehow to explain why it is working for some and not for others?
    Nick Carthew Online
    Nick Carthew Online
    @Thomas-Scharrer said in Has the Motorbike problem been fixed in 4.0.3???:
    I wouldn’t have thought that would make any difference.
    A good test would be:
    Try starting a route with your screen on so that you can hear instructions and then turn your screen off.
    That’s how I tested.
    Thomas Scharrer Con Hennekens 2 Replies Last reply
      Thomas Scharrer Offline
      Thomas Scharrer
      @Nick-Carthew
      I have even tested this in the car a while ago to have better control of what is happening.
      I put my helmet with my Sena on max volume on the passenger seat . I started a navigation, drove around and everything worked fine but as soon as I turned around the phone so it became inactive / locked the voice guidance stopped.
      I then started another navigation with google maps and I could do whatever with my phone and it worked.
      and for @Corjan-Meijerink it also didnt work when he tested
      Nick Carthew 2 Replies Last reply
        @Nick-Carthew
        Nick Carthew Online
        Nick Carthew Online
        What do you mean when you say you turn your phone around so it became inactive?
        I use the off button on the side of the phone to turn the screen off.
        I can assure you that it worked for me as described earlier.
          Thomas Scharrer
          @Nick-Carthew its also fine to use the off button but I had the phone lying on the passenger seat facing up and turned it around to face down so it becomes inactive
            Nick Carthew Online
            Nick Carthew Online
            #25
            @Thomas-Scharrer Well I suggest that whatever setting you have that turns your screen off when you turn it over is causing the problem. When navigating my screen stays on when I turn it face down.
              Con Hennekens Online
              @Nick-Carthew said in Has the Motorbike problem been fixed in 4.0.3???:
              I tested exactly that with my two android phones this morning, after allowing the app on them both to be running in the background.
              The results on both: NO audio whatsoever. What strikes me on both phones is that the message that is halfway spoken when I push the lock button gets finished perfectly fine, so lock mode does not seem to interfere with that, and talking in lock mode is perfectly possible. BUT there are significant differences between them even so.
              When I unlock my CAT I need to give it the unlock sequence first and select the app to display because it shows the homescreen first. But it is on the right spot immediately and resumes the voice guidance. It looks like the route has been followed correctly all along.
              When I unlock my P30 Pro it skips the unlock procedure and focuses on the app immediately, the map scrolls from the old position (where it got locked) to the current position and resumes voice guidance. So it looks like it was not following the route all along.
              Now it could be of course that the CAT scrolled to the current position in the time between pushing the lock button and finishing the unlocking procedure, but I can't be sure about that.
              So, it feels to me that voice guidance is not triggered in lock mode (on Android), and I have to assume the app is not following the GPS at all in lock mode.
                Nick Carthew Online
                Nick Carthew Online
                @Con-Hennekens said in Has the Motorbike problem been fixed in 4.0.3???:
                Interesting, so we have two Android phones that do not play audio, one iPhone that doesn't and one iPhone that does!
                Are the location permissions the same for both phones?
                  #28
                  @Nick-Carthew, yes they were identical and set to "always allow". I think maybe the location services themselves fall into sleep mode when locking the screen, but I cannot find any setting for that.
                  EDIT:
                  I did find this text on the internet however:
                  Concerning our use case, ACCES_BACKGROUND_LOCATION permission should be in the manifest, but I cannot imagine that being not the case.
                  The last yellow sentence would indicate that our use case is not possible at all, a few times an hour is clearly not enough. So I assume there is more to it than can be read here.
                  source: https://developer.android.com/training/location/background
                  richtea999 Thomas Scharrer 2 Replies Last reply
                    @Corjan-Meijerink said in Has the Motorbike problem been fixed in 4.0.3???:
                    We will work on this in the future! 🙂 Currently the app indeed does not continue the instructions when the screen is locked.
                    Yes it does, I have just tested it. 100% all instructions and camera warnings.
                    Rob Verhoeff Online
                    Rob Verhoeff Online
                    #29
                    I can confirm this. This morning, while driving and navigating, I opened a different app on my iPhone 13 for a moment (😇 ). To my big surprise, the voice instructions continued to provide route guidance. An undisclosed feature?
                      @Rob-Verhoeff, well I don't think running out of focus is identical to running with locked screen. I have not tested that. I will (for Android) when I get the chance.
                        EDIT:
                        richtea999 Offline
                        richtea999 Offline
                        #31
                        The app definitely asks for ACCESS_BACKGROUND_LOCATION, so in general it should work OK in the background on Android if the user or OS hasn't restricted permissions (accidentally or otherwise).
                        [Note that the OS is getting more invasive nowadays (Android 11 onwards?), and it can disable permissions - but only if the app hasn't been used recently, for many days for example. But that's not the case here.]
                          Rob Verhoeff Online
                          Rob Verhoeff Online
                          @Con-Hennekens That's indeed an interesting question! My screen wasn't locked, but MRA had been pushed to the background momentarily. I'll give it a try soon with a locked screen while navigating a route.
                            EDIT:
                            Thomas Scharrer
                            @Con-Hennekens Very interesting behavior, my question still is why this works perfectly with google maps navigation?
                            I tried this with several scenarios, not only locking the screen but even going out of google maps and here you get sometimes a message on the home screen asking if you want to continue running the navigation or abort.
                            I guess this functionality is simply missing in MRA navigation?
                              @Thomas-Scharrer, No idea. There are many "secrets" in Google software that only Google knows 😉 But this one is likely a thing that the MRA Dev team will solve.
                                @Nick-Carthew
                                Nick Carthew Online
                                Nick Carthew Online
                                @Thomas-Scharrer I made a short video in the car yesterday and put it on YouTube. This shows my glamorous assistant switching the screen off and the instructions can still be heard, turn the screen back on and the app can be seen running in the background.
                                https://youtu.be/nctharxZffQ
                                Lynchy67 Rob Verhoeff 2 Replies Last reply
                                  Lynchy67 Offline
                                  Lynchy67 Offline
                                  Lynchy67
                                  @Nick-Carthew
                                  Finally we get to see those sausage fingers! 🤡
                                  • Lynchy67 Lynchy67
                                    @Nick-Carthew
                                    Nick Carthew Online
                                    Nick Carthew Online
                                    @Lynchy67 said in Has the Motorbike problem been fixed in 4.0.3???:
                                    @Nick-Carthew
                                      Rob Verhoeff Online
                                      Rob Verhoeff Online
                                      #38
                                      @Nick-Carthew yep, great to see! That's an iPhone too so to see, so my earlier confirmation is confirmed so to say 😁
                                        Thomas Scharrer
                                        @Rob-Verhoeff thanks for the video, very strange that it works for you and not for others. Would be really interesting to understand why
                                          Nick Carthew Online
                                          Nick Carthew Online
                                          @Thomas-Scharrer It works for @Rob-Verhoeff on his iPhone too so I can only assume that it’ll be connected to your phone settings.
                                          Hans van de Ven MR.MRA
                                          Thomas Scharrer
                                          Thomas Scharrer
                                          Lynchy67
                                          Lynchy67
                                            25
                                            62
                                            19.9k
                                          • Max distance for scenic route generator in the Nav App
                                          • App not opening
                                            677
                                          • I can't see Road Closures
                                          • Offline Navigation
                                            PeterKerkhof
                                            PeterKerkhof
                                          • Hoog aantal reisuren bij kiezen bestemming in app
