  3. Points of interest selection lock up
14 Posts 9 Posters 3.8k Views
  • Jure Sirena 0 Offline
    Jure Sirena 0
    wrote on last edited by Jure Sirena 0
    Hi I dont know if this is part of app or Route lab, but at the end route lab is part of app...
    Today the selection of POI is always manual per each root. Example if you have a trip based on 10 days, you need to select POI for maps on each route for each day from scratch.
    It wouldbe easier if POIs could be selected in general, because POI's like parking, caffee, sites, fuel....are ALWAYS used. So in this case we would only manage POI's per route that are not needed, or select special ones per route, but this is unlikely.
    Thanks
    Nick Dawson Inge Bakermans Iris 4 3 Replies Last reply
    • Nick Carthew Nick Carthew moved this topic from [Beta] Suggestions and Discussions on
    • Nick Carthew Offline
      Moved from beta navigation to general discussion
      • Jure Sirena 0 Jure Sirena 0
        Thanks
        Nick Dawson Offline
        Nick Dawson Offline
        Nick Dawson
        @Jure-Sirena-0 yes, it is a pain to always have to choose POI's on a multi day trip but I would not like POI's to always be on either.
        If there was some way to mark a multi day trip and globally switch POI on or off then that would be excellent from my point of view!
          Thanks
          Inge Bakermans Offline
          Inge Bakermans
          @Jure-Sirena-0 Absolutely agree with you. It is a pain to constantly have to switch them on when changing routes/ maps. Would indeed love to be able to keep them on and/or be able to switch them off in 1 go as Nick suggests. Hopefuly MRA implement this soon.
          Jure Sirena 0 1 Reply Last reply
          • Inge Bakermans Inge Bakermans
            Jure Sirena 0
            @Inge-Bakermans I agree, Nicks point also makes lot of sense.
              Jure Sirena 0
              @Jure-Sirena-0 said in Points of interest selection lock up:
              Any progres here? Doing 14 day trip and choosing everytime POI for each day seperately is huge pain in the bottom part. As soon as you step out of route, or change it, you have to do POI selection all over again..........I dont recall any other provider to have such option, once you turn POI on they stay on.....selectively of course.
              Many thanks
                Thanks
                Iris 4 Offline
                Iris 4 Offline
                Iris 4
                @Jure-Sirena-0 This would be very useful!!
                  Many thanks
                  @Jure-Sirena-0 @Iris-4
                  The RoutePlanner is due for an update when all of the MRA Navigation Next development work is complete. Later this year.
                  Jure Sirena 0 Desertfox1603 2 Replies Last reply
                    Jure Sirena 0
                    @Nick-Carthew
                    I have a feeling MRA Next overvelmed the team….
                      @Nick-Carthew
                      Corjan Meijerink Offline
                      @Jure-Sirena-0 overwhelmed? No! Prioritised? Definitely! 🙂
                        @Nick-Carthew
                        @Jure-Sirena-0, Why would you say that? They have a public release exactly on the day like it was planned?
                          Desertfox1603 Offline
                          Desertfox1603
                          @Nick-Carthew Hi Nick, what`s about the Update which will resolve the problem for Points of interest selection lock up which was described by Jure Sirena?
                          Greats Dietmar
                          • Greenham Offline
                            Greenham Offline
                            Greenham
                            Is it possible to just load the POI's into the GPS rather than the application? At least for now until the update later.
                            • Greenham Greenham
                              @Greenham, depends on your device, but in the case at hand it is about the MRA Navigation app.
                              @Desertfox1603 said in Points of interest selection lock up:
                              Partly... A GREAT LOT has changed since then, about how the personal POI library works. You can enable / disable them in the planner, and even lock them to your profile, so they will always show (even during navigation in the app!). But for the default HERE POI categories this is unfortunately not possible.
                              Nick Dawson
                              Nick Dawson
                              Inge Bakermans
                              Inge Bakermans
                              Greenham
                              Greenham
                              Desertfox1603
                              Desertfox1603
                              Jure Sirena 0
                              Jure Sirena 0
                              Iris 4
                              Iris 4
                                1.6k
                                15.8k
                              • HERE maps updates
                                576
                              • bundel purchase
                              • Complimenten
                              • Wegwerkzaamheden / Road works
                                veghelvan 0
                                veghelvan 0
