  3. Re-arranging RP's issues
13 Posts 5 Posters 2.0k Views 1 Watching
  • Kenneth de Miranda Offline
    Kenneth de Miranda
    Hi, when using MRA Next (desktop/iPad) and adding a RP to a (long) route I cannot re-arrange that new RP to a different position by drawing it. It wil work when Moror or less on the same page of RP's but if you want to drag it to let's say between the first and second RP it wil not work.
    What I also find is that, in the dektop version at least, if I use the space bar in text edit, it crashes. When I enter the forum though the regular https://www.myrouteapp.com/route/open/7570968 browser version, both issues as mentioned above work fine. So it's only when I use MRA Next (on the desktop/iPad) that these occur.
      Kenneth de Miranda
      ...drawing should be dragging of course 🙂
      • Nick Carthew Online
        Nick Carthew Online
        Your question refers to the MRA RoutePlanner not MRA Navigation Next so I will move the topic to the General discussion area.
        Kenneth de Miranda 1 Reply Last reply
        • Nick Carthew Nick Carthew moved this topic from [Beta] Problems, Bugs and other Issues on
          Kenneth de Miranda
          @Nick-Carthew uhh actually not. It does refer to the MRA Next, as I explained in the description. The issues doe not appear in the regular MRA planner. So, since the MRA Next will be one platform (planning + navigation) it is suited for beta testing as well I presume.
          Nick Carthew Con Hennekens 2 Replies Last reply
          • Kenneth de Miranda Kenneth de Miranda
            Nick Carthew Online
            Nick Carthew Online
            @Kenneth-de-Miranda MRA Navigation Next is a navigation module that is added to the MRA Mobile app. MRA Navigation Next is unavailable for the desktop PC or Mac.
              Kenneth de Miranda
              @Nick-Carthew aha, ok.
                @Kenneth-de-Miranda. The planning module in MRA Mobile is actually an embedded view to the website, so we are speaking about the same thing 😉 . In the mobile view you can double tap the route line in between 2 WP and an extra WP will be placed. Lastly you can drag that point to the desired location
                  Kenneth de Miranda
                  @Con-Hennekens now, that is one of the best tips so far 🙂 did not know that the double tap inserted a RP in the right order. Maybe I should read the manual 🙂 Thanks!
                  Con Hennekens RetiredWingMan 2 Replies Last reply
                    @Kenneth-de-Miranda, Thanks 😉 The double tap functions like a single click in a PC browser. I think me too learned that here on the forum.
                      Stefan Hummelink Offline
                      @Con-Hennekens but for me a single tap on the route line works also?
                        @StefanHummelink, Well now breaks my clogg... 🤣 You are totally right!
                          RetiredWingMan Online
                          @Kenneth-de-Miranda you can also long press a waypoint and then, without releasing, move the waypoint to another location.
                            @Con-Hennekens and for me this has been like this also in the previous app. 😋
                            Kenneth de Miranda
                            Kenneth de Miranda
                            • Welke instelling
                              426
                            • nieuwe Belgische gebruiker
                              chris 18
                              chris 18
                            • Update 5.2.2 - Quick fix
                              1.4k
                              Pim van Dongen
                              Pim van Dongen
                              359
                            • Elektrisch voertuig
                              161
                            • Position Arrow
