  4. Offline Map Update
Offline Map Update
15 Posts 6 Posters 339 Views 1 Watching
  • GT JWRundefined Offline
    Offline Map Update is not working - and cannot use offline maps until this is sorted. This issue has been happening for at least the last 4-5 days.MRA - Offline Maps Update Failure.png
    • Corjan Meijerinkundefined Corjan Meijerink moved this topic from General Discussion on
    • GT JWRundefined GT JWR
      @GT-JWR-0 offline maps stability is something we will definitely work on. I’d try restarting the app or eventually reinstalling 😞
        @Corjan-Meijerink did both, neither worked.
        christopherjknightundefined 1 Reply Last reply
          christopherjknightundefined Offline
          christopherjknight
          @GT-JWR I have the same problem. Additionally, I can't set offline navigation - the switch doesn't work.
          GT JWRundefined Corjan Meijerinkundefined 2 Replies Last reply
          • christopherjknightundefined christopherjknight
            @christopherjknight was hoping it was related to the recent beta issue...appears it is not. I've updated my iOS and same issue present.
              @christopherjknight that’s disabled on purpose - we still need to develop that! Will be implemented in the coming weeks 💪
              @GT-JWR the outage of MRA Navigation was completely unrelated to this 🙂
              • Walter Coadyundefined Offline
                Walter Coady
                Same here, I have reinstalled the app as well.
                  @Corjan-Meijerink any update on a possible resolution?
                    @GT-JWR not actively working on this now. A reinstall should have fixed the issues. If not, is your storage by chance full?
                    GT JWRundefined 2 Replies Last reply
                      @Corjan-Meijerink reinstall did not correct it, and there is no issue with storage capacity on iPhone. I will try the delete and re-install one more time.
                        @Corjan-Meijerink - FYI, 2nd uninstall, reboot of iPhone, reinstallation corrected the issue.
                          @Corjan-Meijerink after yesterdays update to the latest version, once again, the Update for maps was needed - and the same 'Something went wrong' error came up. Rebooting the phone (iPhone 11) made no difference.
                          Had to delete TestFlight and app, reinstall, and the re download all the offline maps I wanted.
                          Painful, time consuming process - is this a bug? Issue happening anywhere else?
                            Nick Carthewundefined Online
                            @GT-JWR Not a bug as I also have an iPhone 11. No problems at all with offline maps.
                            • Jörgenundefined Online
                              I wanted to add a Belgium map for the weekend yesterday, but any additional map can not be loaded until the current one gets an update, but the update did not work.
                              So, I tried this morning, and now I get the error "something is not working".
                              I can not see what I have already downloaded and I can not add anything. 😧
                              • Jörgenundefined Jörgen
                                @Jörgen exactly what has happened on 2 seperate update occasions. And the only fix was to delete the apps, reboot the phone, reinstall the apps and re download the offline maps wanted.
                                GT JWRundefined
                                Walter Coady
                                christopherjknight
                                  Peter Zehentreiterundefined
                                  9.3k
                                  AWDC LAOundefined
                                  23
                                  45
                                  1.0k
                                • Vrij rijden
                                  Rob Verhoeffundefined
                                • Anzeige momentane Position (Routing) - Exportfunktion Routen (IOS)
                                • Franse Alpen route
                                  Lex.Kloet.RXundefined
                                  Lex.Kloet.RX
                                • 3 English training sessions added to the MRA Academy
                                • Hi everyone!
                                  Albert van den Elsenundefined
                                  89
