  4. Lane assistance incorrect UK
13 Posts 6 Posters 77 Views
  • Ian foster 0 Ian foster 0
    @Corjan-Meijerink morning see picture of example . Below is a different example of the same roundabout but turning right and the lane display telling me to go in left hand lane . Seems a problem roundabout maybe as I’ve tested a fair few on the way to work but most seem to be fine. Sorry I don’t know how to add a pic
    @Ian-foster-0 said in Lane assistance incorrect UK:
    Ian foster 0 1 Reply Last reply
      Ian foster 0
      Ian foster 0
      Ian foster 0
      • Ronni
        Ronni
        Ronni
        seems correct to me in the picture, the 5th version goes off to the left?
        Greetings
        Ronni
        Samsung Galaxy A56 5G
        Android 16
        One UI Vers. 8.0
        Carpuride W712D
        Silverfox BT Cntroller H1+
        • Ronni Ronni
          Greetings
          Ronni
          Ian foster 0
          Ian foster 0
          Ian foster 0
          @Ronni Should be the right hand lane as turning right to go around the roundabout
            The instruction shows turn left at the fifth exit.
            Ian foster 0 Dae 0 2 Replies Last reply
              Ian foster 0
              Ian foster 0
              Ian foster 0
              @Nick-Carthew ah right I understand now , sorry I thought it was telling me which lane to get in at the roundabout
              Dae 0 1 Reply Last reply
                Dae 0
                Dae 0
                Dae 0
                @Nick-Carthew said in Lane assistance incorrect UK:
                That instruction is definitely wrong in the U.K. Here you go in the right hand lane when approaching a roundabout if the exit you are taking is past the 12 o’clock position, unless signposted otherwise.
                • Dae 0 Dae 0
                  Ian foster 0
                  Ian foster 0
                  Ian foster 0
                  @Dae-0 I think it is telling us that it’s left off the roundabout (5th exit) instead of what I thought it was , I.e what lane to be in approaching the roundabout , hopefully someone can confirm that ?
                    Dae 0
                    Dae 0
                    Dae 0
                    That’s how I understand it - lane guidance.
                    It doesn’t make sense that it’s telling you to turn left to exit the roundabout as that’s the only way to exit one. Any other choice would have you going round the roundabout forever.
                    If it isn’t lane guidance then it needs making much clearer what it’s actually telling you to do. All other nav software I’ve seen use this iconography to tell you which lane to get into, and displaying it the same but meaning something different is not wise
                    • Dae 0 Dae 0
                      Ian foster 0
                      Ian foster 0
                      Ian foster 0
                      @Dae-0 yes totally agree , hopefully this will improve on the later versions
                      Dae 0
                      Dae 0
                      Ronni
                      Ronni
                      Ian foster 0
                      Ian foster 0
                      • Strange translation
                      • Undo/Redo tool is hidden
                      • Crazy routing
                      • Which route is shown?
                        martin-phogel.de
                        martin-phogel.de
                        10.4k
