  4. Next closes immediatly when starting a planned route
problemandroid 12huawei p30 pro
32 Posts 10 Posters 362 Views
    This will be investigated coming week! 🙂
      @Corjan-Meijerink, I have full confidence 😉 I didn't mean to disturb your weekend!
        @Con-Hennekens You haven’t at all 🙂 No worries!
        • Hans Kremers
          Hans Kremers
          Hans Kremers
          For what it ist worth, I'm seeing the same behaviour in a Huawei P20 Pro, Android 10
          After selecting and starting the navigation, the screen goes Black and the Desktop appears
          I tried several routes, all with the same result.
          Starting navigation with the same routes in a Lenovo P11 Pro (Android 12) works fine
          Regards,
          Hans
          Triumph Tiger 800XCa
          Blackview BV6200 / Osmand+
          • Hans Kremers Hans Kremers
            Regards,
            Hans
            @Hans-Kremers Thanks! Tomorrow - Thursday are scheduled for app development so we’ll start the investigation shortly! 🙂
            ASPK 1 Reply Last reply
              ASPK
              ASPK
              ASPK
              Je rencontre exactement le même problème avec mon Samsung S20FE.
              Si je démarre Next, je charge un itinéraire de la bibliothèque, je lance la navigation et l'application se ferme. Si je redémarre une seconde fois, çà fonctionne et je peux ouvrir tous les autres itinéraires sans soucis.
              • Tim  Thompson
                Tim  Thompson
                Tim Thompson
                I tried clearing that app cache and then retried starting the route. That seemed to work. Don't know if it was a coincidence. But for what it's worth.
                • Tim  Thompson
                  Tim  Thompson
                  Tim Thompson
                  #22
                  I've upgraded to the latest beta version 3.2.5 - 146. I uninstalled it and reinstalled. Still having the stability issues. In fact, they may have gotten worse. It's now crashing occasionally when going to the menu (upper left) and selecting "Routes". Tried clearing the app cache again. That doesn't seem to be helping (must have been a coincidence before).
                  In case it helps...
                  • Pixel 5a
                  • Android Version 13, Build number TP1A.221105.002
                  • MRA Beta Version 3.2.5 - 146
                  • Tim  Thompson Tim Thompson
                    In case it helps...
                    • Pixel 5a
                    @Tim-Thompson Remarkable how this very annoying problem exists for a limited amount of users 😞 We will continue researching this coming week! The most annoying part is that we never experienced this issue on any of our Android test devices. We will keep you posted about any progress!
                      Tim  Thompson
                      Tim  Thompson
                      Tim Thompson
                      Another thing I noted... If I really get stuck, I try clearing the app storage. Kind of annoying... But one must do what one must do. So far, this step has worked to get past the issue. However, it may as well be a coincidence too.
                      Anyway... For what it's worth.
                        @Tim-Thompson Indeed, for what it is worth 😉 The issue needs to be resolved by us. It's as simple as that!
                        Tim  Thompson Ã’scar 2 Replies Last reply
                          Tim  Thompson
                          Tim  Thompson
                          Tim Thompson
                          #26
                          Just a thought. Is it possible to implement logging to help troubleshooting/capture the issue?
                            Ã’scar
                            Ã’scar
                            Ã’scar
                            @Corjan-Meijerink FYI, I too have stability issues. This version gives me more problems than 3.2.4. Continuous closures.
                            My smartphone:
                            Pixel 6 pro.
                            Android 13
                            Ulefone armor 12
                            Android 11
                            I have problems in both.
                            • https://t.me/MRa_by_b0hd1
                            • YouTube: @demco17
                              Unfortunately the logs do not really indicate where the issue is yet. We hope to get more information in a next version!
                              Mike Whitwam 1 Reply Last reply
                              • Koen VH
                                Koen VH
                                Koen VH
                                Hi, I also have this issue on the tablets S7, S2 and the smartphone A51.
                                I have this fault when I push the start button immediately after loading the route. When I wait some time, several seconds the route is loaded and another start can be pushed.
                                iPhone SE (2020) - Outikel RT3 (Android 12)
                                  Mike Whitwam
                                  Mike Whitwam
                                  Mike Whitwam
                                  I have downloaded the new version on Android yesterday and I am having same problems, the unit crashes as soon as I try to start the route. I kept getting a message saying the app had a bug. So deleted the app and re-loaded which seems to have solved the problem. Will re-post if problem comes back.
                                  • Tim Thompson Tim Thompson referenced this topic on
                                    I just saw there is a 3.2.5 version now. The problem persists however. In fact it has kept me from navigating and testing at all all this time, and it does that on all my devices. I simply cannot start a route, with exception of a few times. More details are already known by Corjan. I just wanted to say that the new version did nothing in this regard.
                                      @Con-Hennekens Sad to hear that! This week we will research more 🙂
                                      Ã’scar
                                      Ã’scar
                                      Hans Kremers
                                      Hans Kremers
                                      Michel van Hagen MRA-Founder
                                      ASPK
                                      ASPK
                                      Mike Whitwam
                                      Mike Whitwam
                                      Koen VH
                                      Koen VH
                                      Tim  Thompson
                                      Tim Thompson
                                      Andrew Melton
                                      Andrew Melton
                                      • Online map settings
                                        Arjan de Vries
                                        Arjan de Vries
                                      • reis in concept kopieren
                                      • Real-time traffic
                                        MartinW
                                        MartinW
                                        Parantapa
                                        Parantapa
                                      • Suggestion: Route Auto Name
                                        Parantapa
                                        Parantapa
