  4. Next closes immediatly when starting a planned route
problemandroid 12huawei p30 pro
32 Posts 10 Posters 362 Views
  • Tim  Thompson Tim Thompson
    Just adding my 2 cents here...
    I've experienced this problem as well. Once it manifests, it seems to continue to fail (closes immediately when starting navigation). My current work-around is to open a different route and start it. This seems to work consistently. I then go back and select the original route and open/start it. For whatever reason, this seems to work.
    Edit...
    Just to clarify what I mean by starting a route...
    If I get past that point - then all is good. But at times it is an "if".
    Edit^2...
    Also noted it closing unexpectedly with choosing to edit (pencil icon) from this screen.
    @Tim-Thompson, yes, that makes us two of a kind 😉 Bevause it seems to be a very rare problem.
    I already told @Corjan-Meijerink, this in a support chat, in my experience once my first route-load works then, without quitting the app, I can load all thinkabel routes. But when the first load fails, I can't load any route until perhaps by force-closing the app.
      This will be investigated coming week! 🙂
        @Corjan-Meijerink, I have full confidence 😉 I didn't mean to disturb your weekend!
          @Con-Hennekens You haven’t at all 🙂 No worries!
          • Hans Kremers
            Hans Kremers
            Hans Kremers
            For what it ist worth, I'm seeing the same behaviour in a Huawei P20 Pro, Android 10
            After selecting and starting the navigation, the screen goes Black and the Desktop appears
            I tried several routes, all with the same result.
            Starting navigation with the same routes in a Lenovo P11 Pro (Android 12) works fine
            Regards,
            Hans
            • Hans Kremers Hans Kremers
              Regards,
              Hans
              @Hans-Kremers Thanks! Tomorrow - Thursday are scheduled for app development so we’ll start the investigation shortly! 🙂
              ASPK 1 Reply Last reply
                ASPK
                ASPK
                ASPK
                Je rencontre exactement le même problème avec mon Samsung S20FE.
                Si je démarre Next, je charge un itinéraire de la bibliothèque, je lance la navigation et l'application se ferme. Si je redémarre une seconde fois, çà fonctionne et je peux ouvrir tous les autres itinéraires sans soucis.
                • Tim  Thompson
                  Tim  Thompson
                  Tim Thompson
                  I tried clearing that app cache and then retried starting the route. That seemed to work. Don't know if it was a coincidence. But for what it's worth.
                  • Tim  Thompson
                    Tim  Thompson
                    Tim Thompson
                    #22
                    I've upgraded to the latest beta version 3.2.5 - 146. I uninstalled it and reinstalled. Still having the stability issues. In fact, they may have gotten worse. It's now crashing occasionally when going to the menu (upper left) and selecting "Routes". Tried clearing the app cache again. That doesn't seem to be helping (must have been a coincidence before).
                    In case it helps...
                    • Pixel 5a
                    • Android Version 13, Build number TP1A.221105.002
                    • MRA Beta Version 3.2.5 - 146
                      In case it helps...
                      • Pixel 5a
                      @Tim-Thompson Remarkable how this very annoying problem exists for a limited amount of users 😞 We will continue researching this coming week! The most annoying part is that we never experienced this issue on any of our Android test devices. We will keep you posted about any progress!
                        Tim  Thompson
                        Tim  Thompson
                        Tim Thompson
                        Another thing I noted... If I really get stuck, I try clearing the app storage. Kind of annoying... But one must do what one must do. So far, this step has worked to get past the issue. However, it may as well be a coincidence too.
                        Anyway... For what it's worth.
                          @Tim-Thompson Indeed, for what it is worth 😉 The issue needs to be resolved by us. It's as simple as that!
                          Tim  Thompson Ã’scar 2 Replies Last reply
                            Tim  Thompson
                            Tim  Thompson
                            Tim Thompson
                            #26
                            Just a thought. Is it possible to implement logging to help troubleshooting/capture the issue?
                              Ã’scar
                              Ã’scar
                              Ã’scar
                              @Corjan-Meijerink FYI, I too have stability issues. This version gives me more problems than 3.2.4. Continuous closures.
                              My smartphone:
                              Pixel 6 pro.
                              Android 13
                              Ulefone armor 12
                              Android 11
                              I have problems in both.
                              • https://t.me/MRa_by_b0hd1
                              • YouTube: @demco17
                                Unfortunately the logs do not really indicate where the issue is yet. We hope to get more information in a next version!
                                Mike Whitwam 1 Reply Last reply
                                • Koen VH
                                  Koen VH
                                  Koen VH
                                  Hi, I also have this issue on the tablets S7, S2 and the smartphone A51.
                                  I have this fault when I push the start button immediately after loading the route. When I wait some time, several seconds the route is loaded and another start can be pushed.
                                  iPhone SE (2020) - Outikel RT3 (Android 12)
                                    Mike Whitwam
                                    Mike Whitwam
                                    Mike Whitwam
                                    I have downloaded the new version on Android yesterday and I am having same problems, the unit crashes as soon as I try to start the route. I kept getting a message saying the app had a bug. So deleted the app and re-loaded which seems to have solved the problem. Will re-post if problem comes back.
                                    • Tim Thompson Tim Thompson referenced this topic on
                                      I just saw there is a 3.2.5 version now. The problem persists however. In fact it has kept me from navigating and testing at all all this time, and it does that on all my devices. I simply cannot start a route, with exception of a few times. More details are already known by Corjan. I just wanted to say that the new version did nothing in this regard.
                                        @Con-Hennekens Sad to hear that! This week we will research more 🙂
                                        Ã’scar
                                        Ã’scar
                                        Michel van Hagen MRA-Founder
                                        ASPK
                                        ASPK
                                        Mike Whitwam
                                        Mike Whitwam
                                        Koen VH
                                        Koen VH
                                        Hans Kremers
                                        Hans Kremers
                                        Tim  Thompson
                                        Tim Thompson
                                        Andrew Melton
                                        Andrew Melton
                                        • Route wordt afgesneden
                                          Wim Hompes
                                          Wim Hompes
                                        • Map colours and side roads
                                        • OSM Routing with MRA
                                          Pierre c
                                          Pierre c
