  3. GPX 1.1 or 1.2
GPX 1.1 or 1.2
27 Posts 12 Posters 15.4k Views 3 Watching
  • Drabslab Drabslab
    @Carl-Lee said in GPX 1.1 or 1.2:
    Anyway, 1.1 or 1.2?
    Actually, I think that GPX 1.2 does not exist, at least not as an official standard.The current version of the standard appears to be GPX 1.1 released in 2004. (https://www.topografix.com/gpx.asp). The development of that standard seems to have stopped? But the experts of MR can tell a lot more about that probably.
    GPX 1.2 seems to be an MRA or Garmin interpretation of GPX 1.1 that is adding functionality not able to achieve with 1.1?
    Rob Wilkie
    Rob Wilkie
    Rob Wilkie
    @Drabslab Think I'll be sticking with 1.1. I prefer that the Shaping points are included as well as the Via points - easier to modify a route on the go by skipping a shaping point if necessary.
    • Rob Wilkie Rob Wilkie
      Steve Lynch
      Steve Lynch
      Steve Lynch
      @Rob-Wilkie
      GPX1.2 was an example of MRA going the extra mile for its end users of the Garmin XT and some other Garmins.
      Personally I never use GPX1.2 but some end users prefer to only see see the Via Points on the Garmin map.
        @JW-0
        Do you work on a windows PC or a Mac?
        Max viapoints are 28
        JWeetje
        JWeetje
        JWeetje
        wrote on last edited by JWeetje
        @Hans-van-de-Ven-MRA-Master said in GPX 1.1 or 1.2:
        @JW-0
        I work with Windows 11 Hans
        • JWeetje JWeetje
          @JW-0
          @JW-0
          Do you have an Micro sd card in your XT?
          • JWeetje
            JWeetje
            JWeetje
            Yes I have.
            Take it out, or put some garmin xml on it?
            ps: how can I get a notification/email that you answere?
            I have all notifications at notification and email.
            • JWeetje JWeetje
              Yes I have.
              @JW-0
              Take the card out and try it again
              This is what Garmin says in the manual"
              The device does not appear as a portable device or as a removable drive or volume on my computer
              Disconnect the USB cable from the computer.
              Switch off the device.
              Connect the USB cable to your device and to a USB port on your computer.
              TIP: The USB cable should be connected to a USB port on your computer and not to a USB hub.
              The device will automatically turn on and switch to MTP mode or USB mass storage mode. Then an image of the device connected to a computer appears on the screen of the device.
              NOTE: If several network drives are connected to the computer, Windows® may have problems assigning drive letters to your Garmin® drives. For more information about assigning drive letters, see the Help file for your operating system.
              • Steve Lynch Steve Lynch
                @Rob-Wilkie
                I use the exact same method as @Don-Stauffer.
                It works flawlessly for iOS and Android.
                Regarding Using GPX1.1 or GPX1.2 the choice is yours to make.
                If you only want to visibly see the Via Points on the XT map use GPX1.2 .
                If you want to see the Via Points and the Shaping Points on the XT Map then use GPX1.1.
                Some screenshots below from my iPad Pro.
                Open the route directly in the Routes folder not the Routelab.
                For me it shows the pop up in the top right corner on my iPad Pro where I can select Garmin Drive.
                artbone
                artbone
                artbone
                @Steve-Lynch Hi Steve, I'm back again. I think via points are waypoints but what are shaping points? And why would I need them? I had a hard time getting my XT to hook up with my iPad but after I get that fixed it works great. It took about an hour to get everything hooked up and do one trip but then it took two or three minutes each to do two more. Thanks again for the help.
                Artbone
                • artbone artbone
                  Artbone
                  Steve Lynch
                  Steve Lynch
                  Steve Lynch
                  @artbone
                  I am told MRA prefers to call them Routepoints rather than Waypoints.
                  For the XT this means Via Points which you plan to stop at and Shaping Points which Shape the Route.
                  If you use GPX1.2 and additional via Points then you will visibly see the flag icons on the XT map and Hand Icons in MRA RoutePlanner.
                  Via points will announce themselves visibly on the XT screen when approaching them.
                  If you use GPX1.2 and you also have Shaping Points in your Route then the Shaping Points are used to shape the route.
                  Shaping Points will appear in MRA RoutePlanner as Balloon icons but on The XT map you will not see them.
                  Shaping Points will never announce themselves visibly on the XT screen when approaching them.
                  If you use GPX1.1 and use Via Points then you will visibly see the flag icons on the XT map and Hand Icons in MRA RoutePlanner.
                  If you use GPX1.1 and you also have Shaping Points in your Route then the Shaping Points are used to shape the route.
                  Shaping points will appear in MRA RoutePlanner as Balloon icons and on The XT map you will see them as blue dots.
                  Shaping Points will never announce themselves on the XT Screen.
                  • Don Stauffer Don Stauffer
                    @Rob-Wilkie After a lot of work, I gave up on Basecamp and purchased a lifetime Gold MRA membership. I have the Garmin Drive app on my Android phone already, and it has been linked to my Zumo GPS.
                    My workflow to load a route into the Garmin Zumo XT is like this:
                    1. Build the route using MRA, usually from my desktop.
                    2. Open the route on my Android phone using the MRA mobile app.
                    3. Select the Download button from the MRA app on the phone, I have been using .gpx 1.1 format.
                    4. A pop up announces 'File has been saved!' and shows a link for 'Export'.
                    5. Touching 'Export' automatically opens the Garmin Drive app, and asks 'Would you like to send it to your Garmin device?'
                    6. The route then downloads to the Zumo XT. On the Zumo, choose 'Apps', then 'Trip Planner.' Your new route will be visible there.
                    It sounds more complicated than it is, and requires no cable connection.
                    With the exception of a flawed release of the Drive app last year, this process has been very reliable and dependable.
                    -KTM-Don
                    Des Sheil 0
                    Des Sheil 0
                    Des Sheil 0
                    @Don-Stauffer,
                    Hi. I have completed the process axactly as you described and everything works OK until opening up trip planner and the route isn't there. I can use a cable from my PC to XT and it works fine but using garmin drive it fails despite Drive stating file has been transfered. Any ideas?
                    • Des Sheil 0 Des Sheil 0
                      @Don-Stauffer,
                      Steve Lynch
                      Steve Lynch
                      Steve Lynch
                      @Des-Sheil-0
                      In my experience using the Routelab directly with Garmin Drive causes issues on my iPad Pro.
                      Using MyRoute-App Mobile works flawlessly on iOS and Android.
                      See the screenshots I posted above that show each stage of transferring a route to the Garmin XT using MyRoute-App Mobile.
                      Don Stauffer 1 Reply Last reply
                      • Drabslab Drabslab
                        Anyway, 1.1 or 1.2?
                        Carl Lee
                        Carl Lee
                        Carl Lee
                        @Drabslab fair enough, no reason to doubt your specifics but it's there and works perfectly (so far) for what I want it to do which is send me on the exact route I planned and only show me the (via) points I select.
                        Drabslab 1 Reply Last reply
                        • Carl Lee Carl Lee
                          I am not saying it is a bad format or that it has no advantages, just that it is not part of the official standard.
                          Moving away from the standard may lead to long term problems. But, when the standard does not evolving anymore, a company like MRA has no other option it seems
                            @Des-Sheil-0
                            Don Stauffer
                            Don Stauffer
                            Don Stauffer
                            @Steve-Lynch I don't think I can help you. My only issue ever was over 1 year ago, there was a release of the Drive App that failed to download to the Zumo. Since the update (V4.19.37) everything has been fine.
                            Best of luck!
                            Don Stauffer
                              Best of luck!
                              Don Stauffer
                              Steve Lynch
                              Steve Lynch
                              Steve Lynch
                              @Don-Stauffer
                              No Help required here the XT is faultless for me.
                              AXMRDR 1 Reply Last reply
                                @Don-Stauffer
                                AXMRDR
                                AXMRDR
                                AXMRDR
                                wrote on last edited by AXMRDR
                                #25
                                This post is deleted!
                                • HighPeakRider
                                  HighPeakRider
                                  HighPeakRider
                                  I know this topic is very old, not sure if its been discussed again.
                                  I'm not technically knowledgeable about GPX, but
                                  If I use 1.1 transferred to the Zumo via Drive it saves it both as a track and a route. Which seems a good option.
                                  However 1.2 only transfers as a route?
                                  No idea why but does the change which is the better format if you wish to follow the exact route as planned?
                                  I'm usually happed to just follow a line as long as I'm taken the correct way.
                                    -KTM-Don
                                    Em Pir
                                    Em Pir
                                    Em Pir
                                    @Don-Stauffer This is my first forum post. I HAD to find out how to use the forum to THANK YOU Don for giving the steps to easily and successfully get a .gpx from a website to my Zumo XT!!
                                    I do, though, have to (humbly) add that I had to tap [Share] in the MRA app after tapping [Download]..
                                    Don Stauffer
                                    Don Stauffer
                                    Carl Lee
                                    Carl Lee
                                    artbone
                                    artbone
                                    JWeetje
                                    JWeetje
                                    HighPeakRider
                                    HighPeakRider
                                    AXMRDR
                                    AXMRDR
                                    Steve Lynch
                                    Steve Lynch
                                    Em Pir
                                    Em Pir
                                    Rob Wilkie
                                    Rob Wilkie
                                    Des Sheil 0
                                    Des Sheil 0
                                      Axel Lange
                                      Axel Lange
                                    • In het kort......
                                    • Route probleem
                                      Jack 13
                                      Jack 13
                                      162
