  3. My route is broken - Something went wrong while calculating the route
16 Posts 4 Posters 2.1k Views 1 Watching
  • Paul Slater 0 Paul Slater 0
    @jack-van-tilburg Hi, the error message doesn't offer the option to fix the route:
    Ive tried checking each waypoint to make sure it is centred exactly on a road but as soon as I try and adjust one I get the same error once more
    @paul-slater-0
    Hi Paul, please share tje url of your route here. Make sure it is set on Public
    Paul Slater 0 1 Reply Last reply
      @paul-slater-0
      Paul Slater 0 Offline
      Paul Slater 0
      wrote on last edited by Paul Slater 0
      @hans-van-de-ven-mra-master It is currently Private, how do I set it to Public please?
      OK I found out how 🙂
      Here is the route https://www.myrouteapp.com/route/open/5935324
        Paul Slater 0
        @paul-slater-0 I have been to each waypoint and zoomed right in to ensure each is centred on a road. But it still gave the same issue with each waypoint I moved a quarter of an inch.
        Now I have just added a new waypoint after (5) to aid the route, and it is now only calculating the route between points 21 and 22 as far as I can tell
        Hans van de Ven MR.MRA Nick Carthew 2 Replies Last reply
          @paul-slater-0
          No problem here:
          OSM Map:
          TomTom map:
          Here Map:
            Nick Carthew Offline
            @paul-slater-0 When I FULLY zoom in some route points are off the road. If you look at route point 10 you will notice that you will get one of those annoying turns that immediately tell you to turn back.
            912FF036-8CB8-46EE-A6AF-154FF5009ABE.png B915DBCF-8627-4178-8324-772D46EB7024.png 46F9755A-8CF4-4B26-B533-366B6D47E485.png 360C0A61-0552-4387-9C7A-DBF8F67B6B79.png
              @Paul-Slater-0
              I haven't checked the waypoints, as @Nick-Carthew points out, I just opened the route in the different maps, and as you can see it's just being calculated.
                @Paul-Slater-0
                Paul Slater 0
                I checked them using Google Maps, not OSM, but the problem I have now is that the roite is not calculating at all and only showing the connection between the final two points
                Is there a way to "force" a recalc of the whole route from 1 to 22 ?
                Paul Slater 0 Hans van de Ven MR.MRA 2 Replies Last reply
                  Paul Slater 0
                  @paul-slater-0 also the waypoints are now unnamed
                    @paul-slater-0
                    Open the route in the OSM map, go to point 1, zoom in to the max and set the point on the right position on the road, then point 2 etc
                      @paul-slater-0
                      Paul Slater 0
                      @hans-van-de-ven-mra-master Hi, I lready did this. I was using the Google Maps overlay not OSM, but I zoomed in to the maximum on each point (all 22 of them) and made sure it was on a road. The problem seemed to be that even when I dragged the ones that were slightly misplaced, the program then recalcluated for 20 seconds each time, and each time produced the error message as originally posted, so I'm not certain that the adjustments have "stuck", particualrly as the points are still showing as off the road.
                      The thing is, the route was working fine until yesterday evening, all the points were connected and all the waypoints had names.
                      It's beginning to seem like I might need to replot the route from start to finish
                        Jack van Tilburg Offline
                        Jack van Tilburg
                        #14
                        @paul-slater-0
                        Same route point, different maps.
                        You have to organise your route points with the OSM map and without an other overlay.
                        Google Maps
                        Opem Source Map
                        Paul Slater 0 Jack van Tilburg 2 Replies Last reply
                          @paul-slater-0
                          Google Maps
                          Opem Source Map
                          Paul Slater 0
                          @jack-van-tilburg ahh okay, I didn't realise that. Thanks for the tip!
                            @paul-slater-0
                            Google Maps
                            Opem Source Map
                            Jack van Tilburg
                            @jack-van-tilburg said in My route is broken - Something went wrong while calculating the route:
                            And of course the Here map if you use Garmin or MRA Nav
                            And the TomTom map when using TomTom navigation.
                            But the same always applies and that is that you should not use a different overlay.
                            Jack van Tilburg
                            Jack van Tilburg
                            Paul Slater 0
                            Paul Slater 0
                            • Welke instelling
                              122
                            • Ability to change units as your navigating
                              Kev Parry
                              Kev Parry
                            • Steeds maar weer centreren
                              Pim van Dongen
                              Pim van Dongen
                            • nieuwe Belgische gebruiker
                            • Automatic setting for units
                            • scherm bevrirzing
                              Thomas Schäfer
                              Thomas Schäfer
