  3. adapting speed when average is too high
10 Posts 5 Posters 1.9k Views 1 Watching
  • Van Herck Lucundefined Offline
    Van Herck Luc
    Hi,
    I created a route into the mountains following real small roads. The app calculates my driving time at an average speed of 65 km/H which is too fast for me.
    How can I lower the speed and get more accurate expected driving time?
    thx for your suggestions
    drive safe !!
    Luc
    Stefan Hummelinkundefined Larry Stengerundefined 2 Replies Last reply
    • Van Herck Lucundefined Van Herck Luc
      Hi,
      drive safe !!
      Luc
      @van-herck-luc Impossible. The speed limits are incorporated into the map data.
      Van Herck Lucundefined 1 Reply Last reply
        Hi,
        drive safe !!
        Luc
        Larry Stengerundefined Offline
        Larry Stenger
        @van-herck-luc
        The speeds in MRA (and, of course the driving time) are not modifiable to match real world conditions.
        I use BaseCamp to make up for this deficiency. This doubles the effort (plan in MRA, save into BaseCamp, rework duration of stops, etc., then export into GPS) but allows BaseCamp to apply the proper Activity profile (motorcycle, car, etc.) which you can modify to match expected speeds.
        I find the BaseCamp trip duration (and expected time of arrivals) to me much more accurate than MRA.
        Good luck!
          Van Herck Luc
          @stefanhummelink thank you for the info. Was afraid it was ...
          • sudoleaundefined Offline
            sudolea
            I've never had 2 identical "predicted" driving/riding times. Compare BaseCamp to MRA, it's different. Compare MRA to one GPS, it's different. Compare MRA to another GPS, it's different again. I for myself count on my Zümo 595 GPS as being the most accurate of all predictions I have available (MRA, BaseCamp, and 2 GPS's).
            You may be helped making some "staff-check-correction-factor" based on experience...
            Larry Stengerundefined 1 Reply Last reply
            • sudoleaundefined sudolea
              Larry Stenger
              @sudolea
              Sure, but the thing about BaseCamp is that it allows you to modify your activity profile to more closely match your normal rides. You can tune it however you want for speeds on highways, secondary roads, etc.
              I'm never looking for perfect predictions, but MRA is way off and very tough to use for any kind of predictions in my experience.
              sudoleaundefined 1 Reply Last reply
              • Larry Stengerundefined Larry Stenger
                @sudolea
                sudolea
                @larry-stenger You're right, and I know of that fine-grained speed adjustation possibility in BaseCamp. I just never have taken the effort to try to tweak it, as the "standard" riding time prediction of my Zümo 595 is accurate enough for me. I've even noticed that one ride can be significantly different from another one (e.g., you may feel more spirited), which may make a difference too. To me, this is all reason enough to "just" stick with my Garmin Zümo 595's predictions...
                Everyone chooses his own method. Yours may be better for him, mine may be. I just gave the topic starter my hint of the method I used for myself. It has "just" the value of a hint, nothing more ☺
                  Larry Stenger
                  @sudolea
                  "Everyone chooses his own method. Yours may be better for him, mine may be. I just gave the topic starter my hint of the method I used for myself. It has "just" the value of a hint, nothing more ☺"
                  Very true and I apologize if the tone of my note was harsh. I am in the middle of a long ride preparation myself this week (7000 miles/11000km over 3 weeks) and am in the middle of taking the route (from MRA) over to BaseCamp (riding day by riding day) in order to get both an accurate transfer to my NAV VI and also get reasonable time estimates.
                  I originally viewed MRA as a potential replacement for BaseCamp in my route planning process but now I envision it only as a first step.
                  Have a great day and ride safe!
                  Larry
                    @sudolea
                    Larry
                    sudolea
                    @larry-stenger said in adapting speed when average is too high:
                    @sudolea
                    "... and I apologize if the tone of my note was harsh. ...
                    Not needed 🙂
                    Larry
                    Same to you !
                    • Emily 3undefined Offline
                      Emily 3
                      This post is deleted!
                      sudoleaundefined
                      sudolea
                      Emily 3undefined
                      Emily 3
                      Larry Stenger
                      Van Herck Luc
                        white.mouseundefined
                        Huibertusundefined
                        Huibertus
                        733
                        haweboundefined
                        hawebo
                        449
                        John S Parryundefined
                        8.0k
                        M. Schrijverundefined
                        806
                      • Android auto en geluid
                        Brian Sprottundefined
                        Brian Sprott
