  3. Suggestion: use folder structure to select route in apps for navigation and tracking
4 Posts 4 Posters 977 Views 1 Watching
  • Herko ter Horst
    Currently, both the MyRoute-app app and the MRA Navigation app use a single list of all my routes (with the most recently viewed one at the top) in the "Tracking" and "Navigation and tracking" (and "Route planning") screens, respectively.
    While I can see some value in that (especially in situations where interaction should be minimal, such as when using the Navigation app through CarPlay/Android Auto), this usually does not work for me, as I tend to work on/look at routes in any order and I won't typically have openend/worked on the next route I am going to drive last.
    So I would very much like to be able to use my own familiar folder structure to find and select the route to use for tracking and/or navigation, either as a replacement for or in addition to the current list.
    Note that this is specific to tracking and navigation as the "My Routes" section of the MyRoute-app app does show the full folder structure, so an alternative that would also work for me, would be to be able to start tracking and navigating (opening the route in the Navigation app) from a route selected in "My Routes".
      @herko-ter-horst
      Hi Herko, A folder structure is not allowed in AppleCarplay (as far as I know).
      PAD 0 Con Hennekens 2 Replies Last reply
        @herko-ter-horst
        PAD 0
        PAD 0
        PAD 0
        My interpretation of @Herko-ter-Horst's post is that it is expressing a wish to be able to apply and use folder structures directly in the Navigation app, in the same way as is possible in the Route Planner app? CarPlay being mentioned only as an acknowledgement that folder structures might not be compatible with it and its Android equivalent?
          @herko-ter-horst
          @hans-van-de-ven-mra-master said in Suggestion: use folder structure to select route in apps for navigation and tracking:
          Hmm, I guess they consider it a danger to be browsing through folders while driving?
          I also guess they are forgetting that scrolling through endless lists is maybe even more of a danger, and drivers usually do that BEFORE they are driving...
          PAD 0
          PAD 0
            1.7k
            1.5k
          • Elektrisch voertuig
            659
          • New beta! 6.0.0 (514)
            32
            376
          • Hoe kan ik in één route een stuk met en een stuk zonder snelwegen plannen
          • MRA V6.0.0 (515) The viewfinder is somehow inaccurate and does not find it which is not a problem in the WebPlaner./// Suchfunktion ungenau - findet es nicht
          • MRA 6.0.0 (515) Map Detail at Zoom Levels - CarPlay
