  3. Merge two tracklogs?
6 Posts 5 Posters 2.0k Views 2 Watching
  • silberfuchs67
    silberfuchs67
    silberfuchs67
    On my last trip I made a break during driving my route. After the break I realized that something went wrong with the tracklog, so I had to stop and save it. Then I started a new tracklog - this means for this route there are 2 tracklogs exiting now. Is it possible to merge them into one?
    • silberfuchs67 silberfuchs67
      @silberfuchs67 No, unfortunately it is not possible to merge tracklogs. Tracklogs are true recordings with a registered start and end point.
      • Travellexxie
        What should work:
        • make a route of both tracklogs
        • merge the routes (that is possible)
        • save the route as a GPX
        • import the track
          Ok, it is not a tracklog, but it is the track of your ride.
        MRA Lifetime Gold
        • Léon Hassing
          Léon Hassing
          Léon Hassing
          You can combine gpx-files on the internet, e.g. via https://gotoes.org/. Or you can use JaVaWa RTWtool: https://www.javawa.nl/rtwtool.html.
            There are multiple tools available for this:
            https://www.google.com/search?q=merge+two+gpx+tracks
            • silberfuchs67
              silberfuchs67
              silberfuchs67
              Many thanks for your help!
              Léon Hassing
              Léon Hassing
              silberfuchs67
              silberfuchs67
              • MRA Studio export speed
              • route bug
              • Map colours and side roads
              • geeft routepunt niet weer
