  4. Open Street Map on Next APP
5 Posts 2 Posters 1.5k Views 2 Watching
  • Manzo91
    Manzo91
    Manzo91
    wrote on last edited by Manzo91
    Hi, there are any update about the implementation of Openstreetmap navigation and map in Next app ?
    I've notice that some mountain pass here in italy (expecially offroad) when i drive it with next navigation app, with the HERE calculate route are not permitted to drive and also not show, but with openstreetmap calculate route on web they are correctly show and draw.
    I add an example:
    HERE calculate Route
    OpenStreetMap calculate route
    thanks
    • Manzo91 Manzo91
      I add an example:
      thanks
      @Manzo91 If you create the route in HERE, you can selected "Disable seasonal closures" in the toolkit. That should do the trick.
      This option is also available in the app before you start navigating.
      There is no ambition to create a navigation app based on OpenStreetMap
      Manzo91 1 Reply Last reply
        Manzo91
        Manzo91
        Manzo91
        @Corjan-Meijerink hi Corian, thanks for your response.
        As you can see, even if I disable stagional closure, HERE doesn't permit to ride the street.
        The only way is to drive it by track:
        Seems like HERE doesn't permit to drive by this street.
        • Manzo91 Manzo91
          @Manzo91 that’s interesting.
          Then another option is to place a waypoint as far as possible down that road. Then place one after that as close as possible and mark that one as offroad 🙂
            Manzo91
            Manzo91
            Manzo91
            @Corjan-Meijerink i try that, and yes the only solution is the waypoint set as off-road. Thanks for your support!
            Manzo91
            Manzo91
            • Audio cuttet via Bluetooth
              Haug
              Haug
              35.5k
            • One crash today
              superg
              superg
            • Download club route folders
              135
              peha
              peha
              Mosimann
              Mosimann
            • Elektrisch rijden
              John mq
              John mq
