Black area while navigating.
If you check your map settings, what is the tilt set to?
It's just the night sky
I would recommend lowering the tilt.
@Corjan-Meijerink tilt correction +15. So I can see way ahead. Thanks for the reply.
@JP-d In that case, I would lower the tilt
You can only look so far ahead, the rest is shown as "sky".
With your input, this post could be even better π
