Unable to change voice instructions
Hi, guys,
One other problem I have is that I changed the voice from female to male, but it doesn't reflect on the instructions. It remains the same female voice. Any hints?
Nick Carthew moved this topic from [Web] Problems, Bugs and other Issues on
@Flavio-Silva I have the same problem. I have 2 phones so on one I Hane English Australian accent and the other English Nigerian accent. But it keeps on defaulting to an English accent which I love but need to distinguish between devices.
Hi, guys,
@Flavio-Silva Did you try to set youre TTS engine to google. here everything works fine
@Leike-Lodiers Yes, I did. No matter which voice I choose, I get only the default female voice.
@Flavio-Silva, since some versions you can set the voice settings in the app independently from your phone settings. I suspect you are changing voice settings in your phones system menu instead of the MRA app it's Audio menu.
@Con-Hennekens Actually, I´m changing on the sound Menu of the App.
@Con-Hennekens if I change mine while navigating it works. But if I shut the app and reopen it then it goes back to the default.
@JP-d, I do not get the exact behaviour you describe, but I tested and there is definately somethig wrong...
@Corjan-Meijerink, trying to replicate @JP-d's problem, I noticed that no matter what voice I select in the App's audio settings, the voice being used while navigating is the Android system's default. Somewhere, somehow (I am typing this with "Tell me why" from Anita Meyer in the background...) something changed, because this was not the case before.
@JP-d Exactly! It happens to me as well.
