  4. BMW Carpe Iter control hub select function
14 Posts 2 Posters 4.4k Views 2 Watching
  • Mark Hamilton 0
    Mark Hamilton 0
    Mark Hamilton 0
    wrote on last edited by Mark Hamilton 0
    Using Carpe Iter V4C android tablet with Carpe Iter BMW control hub kit.
    MyRoute-app version 4.3.2 348
    Input settings within MRA are set to Carpe Iter BMW control
    I am having trouble using the wonder wheel to select menu items or cycle camera - this function does not seem to work when I move the wheel to the right as I think it should. Is there anyone with experience of the Carpe Iter BMW control hub who might be able to point out where I may have gone wrong?
    The select function seems to work without issue in other apps on the device so I think the hub is ok.
    • Mark Hamilton 0 Mark Hamilton 0
      @Mark-Hamilton-0 there currently indeed is an issue.
      I've fixed something for the 4.3.3 release so let me know how that works.
      Some things got out of sync with Carpe Iter so I actually had a call with them to align things. Not sure if this also applies correctly for the BMW control but I'm working with them as we speak.
      So if it doesn't work yet in 4.3.3, it will in 4.3.4 😃
      Mark Hamilton 0 2 Replies Last reply
        Mark Hamilton 0
        Mark Hamilton 0
        Mark Hamilton 0
        Top man, thanks for the quick reply. I’ll check 4.3.3 when released and feedback.
          Mark Hamilton 0
          Mark Hamilton 0
          Mark Hamilton 0
          Hi Corjan. I have used the tablet today with 4.3.3 357 and there doesn’t appear to be any improvement on control functions. Hopefully this will be resolved with 4.3.4.
          I also miss the panning functionality that you get within Google maps etc using this controller and I also had this with MRA using BarButtons is this going to be possible with the CI BMW controller as for me panning is used more than say menu items or skipping? Tapping vs long press for more functionality maybe..
          I have the full Controller set including the hub and extra 4 buttons
            @Mark-Hamilton-0 Sorry, there is a slight delay in getting our hands on a test device. I'll also reach out to Carpe Iter again to check with them about the expected controls. As of now, no changes yet made for 4.3.4.
            Panning is indeed not possible with this controller.
            The arrow functions got different functionalities attached.
            https://support.myrouteapp.com/en/support/solutions/articles/12000100670-bluetooth-controllers
              Mark Hamilton 0
              Mark Hamilton 0
              Mark Hamilton 0
              I’m assuming you mean the CI BMW controller can’t pan within MRA as it does pan with Google Maps, Waze, Locus, DMD2, so the functionality is there just not chosen to do this with the buttons within MRA set up? In my view the panning function is used more when navigating than the current button functions.
              The links from the Manual controllers sections seem like they don’t work, I get ‘Page you were looking for doesn’t exist’! When selecting the individual controller sections.
                Mark Hamilton 0
                Mark Hamilton 0
                Mark Hamilton 0
                @Corjan-Meijerink hello Corjan, is there any update on when this controller (including buttons) will work correctly with MyRouteapp? I did try 4.3.4 with no improvement. I haven’t tried the recent 4.3.5 beta release but it seemed the only change in that was Here SDK.
                  @Mark-Hamilton-0 I've been in touch with them and the working should be correct. I've requested them to test it too.
                  If you still experience issues, could you also contact them?
                  Feel free to add corjan@myrouteapp.com in the cc.
                  I believe there have been some changes regarding direct communication or using the Carpe Control App.
                  Mark Hamilton 0 1 Reply Last reply
                    Mark Hamilton 0
                    Mark Hamilton 0
                    Mark Hamilton 0
                    @Corjan-Meijerink Hi Corjan, thanks for the response. I have tested again today and the situation is better but not fully working. Please view the below and let me know if you think I should still raise with Carpe Iter for them to resolve.
                    Wizz wheel
                    Up - Zoom in works / will move to next menu item
                    Down - Zoom out works / will move to previous menu item
                    Right - Camera cycle works / SELECT MENU ITEM NOT WORKING
                    Four buttons on right throttle twist.
                    Right - START ROUTE NOT WORKING / Skip waypoint works
                    Left - Toggle ETA information working well
                    Up - Fit route to map works
                    Down - Open close menu works.
                      Wizz wheel
                      @Mark-Hamilton-0 Thanks! 🙂
                      I've made some immediate changes that will be available in the next beta version 4.3.6 (380).
                      The select menu should be working! Something was indeed missing there.
                      The start routing already work I believe (as the skip waypoint works too) but you do need to have a route "open" on the home screen.
                        Mark Hamilton 0
                        Mark Hamilton 0
                        Mark Hamilton 0
                        @Corjan-Meijerink hi Corjan thanks for the changes. Hopefully that will solve the issues.
                        I only have beta access to IOS version and obviously Carpe Iter needs Android so unless I can get beta access to Android I’ll have to wait for full release of 4.3.6 to test again?
                          @Mark-Hamilton-0 If you create a support ticket (myrouteapp.com/support) where you mention me and this forum conversation you can request beta access for Android too.
                          Save me one email and already share you google mail that you use on that phone 😉 I will then add you to the beta program for Android too.
                            Mark Hamilton 0
                            Mark Hamilton 0
                            Mark Hamilton 0
                            #13
                            @Corjan-Meijerink hi Corjan, I’ve tested this today using Android beta 4.3.6 381 and can confirm all functions are working as intended. Thank you for making these changes.
                              @Mark-Hamilton-0 Awesome! 🙂
                              Mark Hamilton 0
                              Mark Hamilton 0
                              • Kaart niet zichtbaar
                                201
                                39
                                305
                              • Xpert overlay not clear
                              • Google maps
                                Ed Bos 0
                                Ed Bos 0
                                194
                                124
                                Corrado Miniati 0
                                Corrado Miniati 0
                                Corrado Miniati 0
                                Corrado Miniati 0
