  4. Bug Web & App: I have a very strange bug here. (Here Maps & Avoid motorways)
8 Posts 3 Posters 1.9k Views 2 Watching
  • Holger Niessen
    Holger Niessen
    Holger Niessen
    This only occurs when the Here maps are selected as the basis for calculation.
    If ‘Avoid motorways’ is active, then it makes this strange swerve in the route.
    Although no motorway is used there. Only a bridge is driven over it.
    If motorways are permitted, it does not make this swerve.
    It makes exactly the same mistake in the MyRoute app.
      It is may be a bug in the map data, that a short part is seen as high way.
        @Jörgen I've seen similar situations where the Here map does not properly recognise a highway.
          May be also because of the road works and road closure at this position.
          Holger Niessen 1 Reply Last reply
            Holger Niessen
            Holger Niessen
            Holger Niessen
            @Jörgen I think not. If i enabled Highway the Routine works. I think it‘s an Problem, with the map data.
            R3gards Holger
            Jörgen 1 Reply Last reply
            • Holger Niessen Holger Niessen
              R3gards Holger
              @Holger-Niessen Yes, it's a map error.
              It looks exactly like this on the Here map.
              https://maps.here.com/r/default/Frankfurter Chaussee:52.500685790756705,13.684477633570621/Berliner Straße%2C 27:52.49259335388797,13.78554053904255?map=52.4898,13.77055,13.42
                Holger Niessen
                Holger Niessen
                Holger Niessen
                @Jörgen If you allow Highways the Routing is correct. If it is disabled it is wrong
                  @Holger-Niessen I know, a small part of the B1 is may be rated as Highway.
                  Holger Niessen
                  Holger Niessen
                    Kevin Bird
                    Kevin Bird
                  • Statement on map spinning
                    17
                    36
                    3.5k
                  • First time version 6 and AA
                  • Some minor improvements ;-)
