  4. Bug Web & App: I have a very strange bug here. (Here Maps & Avoid motorways)
8 Posts 3 Posters 1.6k Views 2 Watching
  • Holger Niessenundefined Offline
    Holger Niessen
    This only occurs when the Here maps are selected as the basis for calculation.
    If ‘Avoid motorways’ is active, then it makes this strange swerve in the route.
    Although no motorway is used there. Only a bridge is driven over it.
    If motorways are permitted, it does not make this swerve.
    It makes exactly the same mistake in the MyRoute app.
    • Jörgenundefined Offline
      It is may be a bug in the map data, that a short part is seen as high way.
      • Jörgenundefined Jörgen
        @Jörgen I've seen similar situations where the Here map does not properly recognise a highway.
          May be also because of the road works and road closure at this position.
          Holger Niessenundefined 1 Reply Last reply
            Holger Niessen
            @Jörgen I think not. If i enabled Highway the Routine works. I think it‘s an Problem, with the map data.
            R3gards Holger
            • Holger Niessenundefined Holger Niessen
              R3gards Holger
              @Holger-Niessen Yes, it's a map error.
              It looks exactly like this on the Here map.
              https://maps.here.com/r/default/Frankfurter Chaussee:52.500685790756705,13.684477633570621/Berliner Straße%2C 27:52.49259335388797,13.78554053904255?map=52.4898,13.77055,13.42
                Holger Niessen
                @Jörgen If you allow Highways the Routing is correct. If it is disabled it is wrong
                  @Holger-Niessen I know, a small part of the B1 is may be rated as Highway.
                  Holger Niessen
                    Peter Zehentreiterundefined
                    6.2k
                  • Maximum amount of POI's that can be added ?
                  • Mac to Garmin Zumo XT* GPX Transfer
                    Steve Jarrellundefined
                    Steve Jarrell
                    843
                  • Anyone with CPMC B6?
                    1.5k
                  • App friert ein
                  • Mi spiegate che problemi ha ???
                    Albyusundefined
                    Albyus
                    363
                  • New beta! 5.2.1 (480)
                    Martin Whiteundefined
                    Martin White
                    13
                  • CPMC B6/B7
                    iain.gardengmail.comundefined
