  3. How to avoid closed roads?
5 Posts 4 Posters 1.9k Views 3 Watching
  • Axel Härtl
    Axel Härtl
    Axel Härtl
    Hello forum, when planning a route (A to B), MRA does not recognize closed roads. Google Maps, on the other hand, guides you around these closures when planning your route.
    How can one avoid roads that are known to be closed (e.g. roadworks) when planning a route in MRA?
    Best, Axel
    BMW R 1200 RT
    Tourenorientiert
    MRA lifetime member
    Marinus van Deudekom Rob Verhoeff 2 Replies Last reply
    • Axel Härtl Axel Härtl
      Best, Axel
      @Axel-Härtl turn on the traffic layer in the toolbox. Dit the Netherlands and Germany there are poi lists to heel you
        @Axel-Härtl See here:
          Best, Axel
          @Axel-Härtl Besides the option mentioned above, the app also has 'Traffic aware route calculation' during navigation. So if you're planning an A-to-B route directly in the app, it's also recommended to turn this switch on.
          • Axel Härtl
            Axel Härtl
            Axel Härtl
            Hi youall,
            thanks for your answers. I now know how to navigate with traffic information.
            Best, Axel
            BMW R 1200 RT
            Tourenorientiert
            MRA lifetime member
            Axel Härtl
            Axel Härtl
              32
              Vince Hyde
              Vince Hyde
              11.5k
              b0hd1
              b0hd1
            • Probleem met eigen Stay
              Albert van den Elsen
