  3. Maybe a really stupid question.....but are there any "avoid" or "prefer" options?
10 Posts 4 Posters 3.5k Views 1 Watching
  • Alasdair Denton-Miller
    So I feel I must be missing something here, but I can't seem to find any way in Web, iPad or iPhone versions of MRA to tell it to either avoid or prefer different road types.
    For example, "avoid motorways", "avoid tolls", "avoid unpaved roads", "prefer curvy roads".....
    Am I missing something obvious here or do I need to add loads of waypoints to keep a route off the A26 from Calais down to Reims ?
    Drabslab 1 Reply Last reply
    • Reinhard-32
      Reinhard-32
      Reinhard-32
      Yes, that is possible. Open a route and go to toolkit, avoid and select or deselect your preferences.
      Kindly regards
      Reinhard
      Montana 700i and Mac
      Alasdair Denton-Miller 1 Reply Last reply
      • Reinhard-32 Reinhard-32
        @Reinhard-32 Thanks - but when I open Toolkit (at the top right of the map), under "Routing Options" I can just check or uncheck "Offroad". If I check "Offroad" I just get a straight line routing.
        Then I have "Route Utilities" - with expand, reduce, reverse, split, compare and fit options.
        Then "Editor Settings" with waypoint name, place waypoint and transparency options.
        That's it. I'm not seeing any routing preferences.....
        Reinhard-32 Stefan Hummelink 2 Replies Last reply
        • Alasdair Denton-Miller Alasdair Denton-Miller
          Reinhard-32
          Reinhard-32
          Reinhard-32
          @Alasdair-Denton-Miller
          Have you seen this menue?
          Kindly regards
          Reinhard
            @Alasdair-Denton-Miller Hi Alasdair, probably you are using the OpenStreetMaps map algorithm. As it seems the OSM does not offer these functionalities as it is the free map algorithm.
            Are you a gold member? If so, you better change the map algorithm to either TomTom or Here. That option to change the map algorithm is right next to the toolkit menu button. The route tools such as expand, split etc. are only available to for use by Gold members. Seeing them does not mean being able to use them, that's why My question about you being a gold member.
              @Reinhard-32 Nope - I don't see that at all!
              Looks like it's a "Gold" issue - I am indeed using the OSM map and am not a Gold member (yet)....
                Reinhard-32
                Reinhard-32
                Reinhard-32
                You can use the Garmin or the TomTom map as Gold member only.
                and then you will have the full functionality
                Kindly regards
                Reinhard
                  @StefanHummelink I am not a Gold member....... looks like I am going to need to subscribe.
                  Thanks - I thought it might be something like that....
                  (EDIT: subscribed, and now have access to the avoid options - and the other map options)
                    @Alasdair-Denton-Miller Welcome to the Gold Member club haha. The Gold memberships open up very usefull options. You'll find the small fee for the membership worth it!
                      Drabslab
                      Drabslab
                      Drabslab
                      @Alasdair-Denton-Miller In MRA Web yuo can find these settigns here
                      Have fun
                      Drabslab
                      Drabslab
                      Reinhard-32
                      Reinhard-32
                        guenniguenzelsen
                        guenniguenzelsen
                        Emanuele 5
                        Emanuele 5
                      • Club routes public/private
                      • de connector app Windows
