  4. Route displayed white on white at change of direction
29 Posts 11 Posters 10.4k Views 4 Watching
  • ATLast
    ATLast
    ATLast
    Hi.
    The title says it all.
    This behaviour is not new, but kind of bothering.
    See pics...
    Bart De Medts Mzokk 3 Replies Last reply
    • nomko
      nomko
      nomko
      Banned
      Did you tried a hard reset? Recently updated the devies?
      ATLast 1 Reply Last reply
      • nomko nomko
        ATLast
        ATLast
        ATLast
        wrote on last edited by ATLast
        @Nomko-Nomden said in Route displayed white on white at change of direction:
        It's been like that for months, just didn't bother to take pictures and post it.
        • ATLast ATLast
          ATLast
          ATLast
          ATLast
          @ATLast
          Version 4.3.0 - 321 and no change.... and it makes riding unsafe.
          Am I the only one with this problem ?PXL_20240827_114045200.MP (Moyenne).jpg
          • ATLast ATLast
            Hi.
            See pics...
            Bart De Medts
            Bart De Medts
            Bart De Medts
            @ATLast If you adjust the zoom settings (zoom out) it does become clearer.
            πŸš— Car: iPhone 15 Pro with wireless Apple CarPlay
            • RetiredWingMan
              I think i had a similar problem yesterday. Was driving and coming up to a turn when the screen started to lag and then multiple lines appeared and it all got very confusing. The voice prompts continued normally but you could not tell where you were on the screen. I tapped the compass and switched to top down view and it was instantly cleared up. I didn't have a chance to snap a screen shot.
              • ATLast ATLast
                Hi.
                See pics...
                Mzokk
                Mzokk
                Mzokk
                @ATLast I thought that it was a feature of the Dart colour scheme. I noticed it but it didn’t bother me because the direction panel was ok as were the spoken directions.
                • Bart De Medts Bart De Medts
                  ATLast
                  ATLast
                  ATLast
                  @Bart-DM said in Route displayed white on white at change of direction:
                  Hi Bart.
                  Thank you for your suggestion : I tried it, but it didn't improve anything.
                  It even made, at some point, things worse...
                  The only thing that improved a tiny little bit was to push line opacity to the maximum: then, a vague thin line appears to border the white arrow that covers the route.
                  By the way, you will also notice the difference the arrival time is displayed on the phone and on the Android Auto screen of the bike: the three pictures have been taken at the same moment:
                  • Mzokk Mzokk
                    ATLast
                    ATLast
                    ATLast
                    @Mzokk said in Route displayed white on white at change of direction:
                    Thank you for your suggestion, but I tried to switch between the three themes and it didn't change anything.
                      ATLast
                      ATLast
                      ATLast
                      @RetiredWingMan said in Route displayed white on white at change of direction:
                      Hi.
                      I don't think it is the same problem: mine is constant and occurs only at intersection, when a white line appears over the route.
                      But thank you anyway.
                      • ATLast
                        ATLast
                        ATLast
                        I want to thank all the people taking the time to answer and try to find an explanation/solution: I really appreciate it.
                        I won't include the people @MRA who could easily step in and either give a solution or acknowledge a bug: that would save everyone's time.
                        • cerfskysky.com
                          cerfskysky.com
                          cerfskysky.com
                          I went to Suffolk yesterday using iPhone 15 Max Pro and found that when using MRA Next with the Map Style set to Explore (which I like) on yellow roads the white direction arrows were not very clear and it looked like a break in the road.
                          • ATLast ATLast
                            Hi.
                            Bart De Medts
                            Bart De Medts
                            Bart De Medts
                            @ATLast The white line is an arrow indicating direction. Hence my suggestion to zoom out further, then you will see the full arrow.
                            • ATLast ATLast
                              @ATLast said in Route displayed white on white at change of direction:
                              Don't you think that this a bit harsh? Especially since the solution has been given. Ever considered that this is no bug but a settings thing, probably in the combination with your specific (settings of) your AA/CP headend? I call AA/CP "an extra layer of complexity" for a reason...
                              People were asking for an option to make the routeline less fat, well this is the result.
                                ATLast
                                ATLast
                                ATLast
                                @Con-Hennekens said in Route displayed white on white at change of direction:
                                I tried ll the advices, kindly provided by the community, but they didn't bring and solution. What solved my problem: by playing around with the settings, I have now found a way to keep the arrow surrounded by a tiny blue line, and that helps.
                                Of course I have considered this to be a problem with the AA implementation by Honda, and it is still possible that's the cause, but I also have to take into account that I don't have the problem with Goog Maps, Waze or OSMAnd.
                                • ATLast
                                  ATLast
                                  ATLast
                                  No.
                                  This forum saves MRA's time and money by providing free volunteers help and reports bugs, it is simply a matter of basic consideration to the customers to add a line with a solution or simply states they don't know or can(t help.
                                  I'm in the IT world for a long time now and one of the basic behaviour I always advice people working with me is: don't let a customer's request for help unanswered. And if you can't provide a solution, just let them know.
                                  And for example, looking at your answer here, these two posts seem to me now probably linked and MRA could have answered easily:
                                  https://forum.myrouteapp.com/topic/7030/4-1-3-misdirection-and-hard-to-decode-displayed-route
                                  https://forum.myrouteapp.com/topic/7806/recalculation-of-the-route-does-not-point-to-final-destination?_=1726302387329
                                  It doesn't take long for the people behind the app to have answered and save people's time.
                                  We are paying customers...
                                  BMcG 1 Reply Last reply
                                  • ATLast ATLast
                                    No.
                                    BMcG
                                    BMcG
                                    BMcG
                                    Hi @ATLast I do have to say I agree with @Con-Hennekens it seems a little harsh to expect a team the size of MRA to respond to every question on the forum.
                                    I agree with your principle that it would be nice for the MRA team to acknowledge a problem but the MRA team is tiny & the customer base is huge in comparison & we ask a lot a lot of questions πŸ˜‚
                                    It actually surprises me how many questions they actually respond to but as you say they are getting good feedback so it helps them.
                                    It is a balance & sometimes you will get a response, others you won't
                                    BlackView BV7100, Android 12
                                    • BMcG BMcG
                                      ATLast
                                      ATLast
                                      ATLast
                                      @Brian-McG
                                      But then, what's the point of creating a forum to report bugs and problems if you don't reply to the posts?
                                      Rob Verhoeff Nick Carthew MotoCon 3 Replies Last reply
                                      • ATLast ATLast
                                        @Brian-McG
                                        Keep in mind that it is still holiday seaseon! That being said, the developer has also responded to various topics. And that's while you're actually on vacation and should be able to take a break from work!
                                        • ATLast ATLast
                                          @Brian-McG
                                          @ATLast It is a community forum that is monitored by MRA staff, especially this channel for reporting bugs. I don’t consider this to be a bug, make the route line thinner in the navigation settings to be able to see more clearly.
                                          Mzokk
                                          Mzokk
                                          BMcG
                                          BMcG
                                          Bart De Medts
                                          Bart De Medts
                                          cerfskysky.com
                                          cerfskysky.com
                                          nomko
                                          nomko
                                          ATLast
                                          ATLast
                                          • reis in concept kopieren
                                          • Suggestion: Route Auto Name
                                          • Trips, interaction with Clubs
                                            Andy Nicholson
                                            Andy Nicholson
                                          • Globale inhoud van een update en mogelijk wijzigingen.
                                            Peter 12m
                                            Peter 12m
                                          • Move Google Maps up the list
                                            JP d
                                            JP d
