  4. Not Re-Routing or turns using the Cycle / Bicycle option
3 Posts 2 Posters 755 Views 2 Watching
  • Robin Ashworth
    Robin Ashworth
    Robin Ashworth
    When following routes with bicycle as means of transport App does not give directions or do a re-calculate if route is not followed. Is there a way to change this?
    • Robin Ashworth Robin Ashworth
      @Robin-Ashworth That is correct! Ther is no voice guidance when transportmode is bicycle!
      The map provider Here includes few to no bike paths in its maps. Therefore, voice instructions for cycling modes are not available in the navigation app. However, you can still create and follow routes perfectly if you base the route on the OSM map. You can then simply follow the line while still using this app.
      Robin Ashworth 1 Reply Last reply
        Robin Ashworth
        Robin Ashworth
        Robin Ashworth
        @Rob-Verhoeff Thanks Rob.
        I think that is what I am doing.
        The track is always calculated correctly but if I deviate too far (i.e. get lost or make diversion!) then I have to stop and re-calculate by entering destination again. I thought there maybe a better way, but maybe not...
        Robin Ashworth
        Robin Ashworth
          795
          Axel Lange
          Axel Lange
        • In het kort......
        • View a route from the previous planner
        • Gesproken aanwijzingen per instructie erg laat
