  4. Voice guidance issues, not loud enough
13 Posts 5 Posters 117 Views 3 Watching
  • UltraStar
    UltraStar
    UltraStar
    I have not seen any one reporting this issue lately. I am thinking that I am only one having these issues. 😞
    First, I still think that the voice guidance has too low volume. I have it set to max in the application, and still have to play the music very loud to hear the voice announcements clearly. If I set the music to low volume (where is comfortable to listen,) the voice is too low, and between the road noise and focus on the road ahead, it is difficult to listen to the voice.
    I am using iPhone12P with the helmet communicator, and my car (Nissan) audio. In both cases the voice guidance is too low.
    Also, while I use the communicator (not sure about the car,) when I pause the music to have the thoughts to myself, the voice guidance is silenced too. Missed the turns several times.
    Love the app, and I use it constantly when riding the bike, and mostly in the car. What am I doing wrong?
    • UltraStar UltraStar
      @UltraStar, I assume this is when your phone is also the source of the music (spotify or YouTube Music or whatever music app). In that case you are not doing anything wrong. This is just how it is. MRA cannot make the voice louder than it really is. The problem is the fact that Android still has no native "volume per app" feature. I am not sure how this is in iPhones, but considering your question, likely the same.
      Rob Verhoeff UltraStar 2 Replies Last reply
        @Con-Hennekens said in Voice guidance issues, not loud enough:
        Voice instructions are loud enough for me...
        MotoCon Theo Lammerts 2 Replies Last reply
          @Rob-Verhoeff said in Voice guidance issues, not loud enough:
          Yes, for you maybe, but can you set the volume independently from music playing natively on the phone (no CP / car radio or anything, but streaming from your phone). Does the voice instruction manifest as a navigation channel in your volume settings, or is it mixed with the music in the media channel?
          UltraStar Rob Verhoeff 2 Replies Last reply
            UltraStar
            UltraStar
            UltraStar
            @Con-Hennekens Thank you, you are absolutely correct. I use the iPhone's native music application to source music while I ride.
            I just remembered reading something about separate channel for the voice prompts and music on the iPhone. I guess that does not help me much.
            Thanks for your help. πŸ™‚
              UltraStar
              UltraStar
              UltraStar
              @Con-Hennekens The volume settings are for both, music and voice. When I here music and adjust the volume up, the voice is getting louder. When I here the voice and adjust the volume up, I here the music louder too after the voice is done.
              It sims like the voice and music are synchronized as the volume goes. I have set the volume of the voice in the MyRoute-app to the maximum, otherwise I would not hear it at all. While I ride and listen to the music at the certain volume, when the voice come the music volume goes low, and comes back after the voice prompts are done.
                @Con-Hennekens In MRA, I set the volume to max through the audio menu. Music comes from the iPhone via a radio app or Spotify. The sound is transmitted through my Sena 30K. The volume of the voice instructions is more than sufficient, and I can adjust the music volume down as desired using the Sena.
                UltraStar 1 Reply Last reply
                  UltraStar
                  UltraStar
                  UltraStar
                  @Rob-Verhoeff Thank you. I have to try the radio app or Spotify. Maybe that will make a difference. I will let you know.
                    @UltraStar in any case, don’t use exotic or Siri-voices. Use one of the standard voices of iOS.
                      UltraStar
                      UltraStar
                      UltraStar
                      @Rob-Verhoeff You are very gentle describing these voices as "exotic." πŸ˜‚
                        @UltraStar said in Voice guidance issues, not loud enough:
                        This is fully consistent with how it works in Android πŸ˜‰
                          Theo Lammerts
                          Theo Lammerts
                          Theo Lammerts
                          @Rob-Verhoeff ik gebruik MRA in combinatie met de iPhone 15 en CarPlay. Het geluid wordt goed weergegeven (gebruik geen radio of andere bronnen voor muziek). Echter na een koffiestop en de route vervolgen is het geluid weg.
                          Start ik de route opnieuw (na verwijderen reeds gepasseerde punten) gaat alles wat het geluid betreft weer ok.
                          Wellicht een bug?
                          Michel van Hagen MRA-Founder 1 Reply Last reply
                          • Theo Lammerts Theo Lammerts
                            Wellicht een bug?
                            Administrator
                            @Theo-Lammerts Dat is inderdaad een bug, wordt aan gewerkt. Voor nu helpt het om de navigatie te stoppen en daarna te hervatten.
                            β€œPeople don’t take trips, trips take people.” – John Steinbeck
                            Theo Lammerts
                            Theo Lammerts
                            UltraStar
                            UltraStar
                              Michael 2v
                              Michael 2v
                            • Map Layers
                              Martin White
                              Martin White
