  4. Having a foreign language at the profile
12 Posts 3 Posters 2.6k Views 3 Watching
  • Cookie On Tour
    Cookie On Tour
    Cookie On Tour
    Hello,
    when having "German" (as an example) setup at the account (profile) and going to the Help and Support section, the website is clean and not showing any articles, links, or videos etc.
    I learned from the forum that I would find articles there to make my live easier to start with the apps, but I was seeing nothing 馃槥
    Can you please consider doing either the one or the other or multiple options to improve the situation please?
    • When a foreign language is configured, show an info box to give an information about content that might be hidden due to language settings at the users account.
    • Showing English as default (or make a fall-back language configurable at the user account)
    • Giving an option to make an easy switch between languages without the need to reconfigure the profile (account)
    I mean, I want to keep my preferred language, but if that is not available, I still want to see something. When the default language is not available, there could be a message like "sorry this content is currently not available in your preferred language".
    Many thanks
    Joerg
    (Cookie-On-Tour.de)
    Duster Laur茅ate SCe 115 LPG 4x2 路 Everest Minicamp by Niewiadow (B1300)
    Carpuride W701 Pro 路 iPhone 15 Pro Max
      Hello,
      Many thanks
      @Cookie-On-Tour I鈥檒l forward this to the support division! 馃檪
        Cookie On Tour
        Cookie On Tour
        Cookie On Tour
        @Corjan-Meijerink thanks a lot!
        Joerg
        (Cookie-On-Tour.de)
          @Cookie-On-Tour If I switch to German, and click "Unterst眉tzung" I see this after being redirected to myrouteapp.com/support
          What do you see?
            What do you see?
            Cookie On Tour
            Cookie On Tour
            Cookie On Tour
            @Corjan-Meijerink Oh dat is interessant, dat is wat ik krijg weergegeven
            Joerg
            (Cookie-On-Tour.de)
              @Cookie-On-Tour Waar heb je op geklikt voordat je op deze pagina kwam?
              Cookie On Tour 2 Replies Last reply
                Cookie On Tour
                Cookie On Tour
                Cookie On Tour
                @Corjan-Meijerink Ik heb verschillende dingen geprobeerd, waaronder de hoofdnavigatie bovenaan het scherm en dan ook linksonder in de browser, vanwaar je ook de helppagina's kunt openen.
                Joerg
                (Cookie-On-Tour.de)
                  Cookie On Tour
                  Cookie On Tour
                  Cookie On Tour
                  Als ik de taal in mijn profiel instel op Engels en naar de helppagina's ga, zie ik de Engelse inhoud, als ik terugschakel naar Duits en de helppagina's opnieuw bezoek, zie ik nog steeds de Engelse artikelen, maar zodra ik de website opnieuw laad, is alles weer leeg.
                  Joerg
                  (Cookie-On-Tour.de)
                    @Cookie-On-Tour Interessant!
                    Werkelijk geen idee hoe dat kan op dit moment 馃檪
                    Misschien dat het nog uit maakt dat je daadwerkelijk in Duitsland bent.
                      Cookie On Tour
                      Cookie On Tour
                      Cookie On Tour
                      @Corjan-Meijerink Normaal gesproken zou ik zeggen dat het een cacheprobleem is, maar ik heb de cache van mijn browser gewist en ook een andere browser geprobeerd, helaas met hetzelfde resultaat.
                      Joerg
                      (Cookie-On-Tour.de)
                        If you head over to myrouteapp.com/support, how are things looking today? 馃檪
                        • J枚rgen
                          J枚rgen
                          J枚rgen
                          https://forum.myrouteapp.com/topic/7512/unterst眉tzung-und-dann-wie-geht-es-einfach-zur-anleitung-dem-handbuch/12
                          With your input, this post could be even better 馃挆
                          J枚rgen
                          J枚rgen
                          Cookie On Tour
                          Cookie On Tour
                          • Route wordt afgesneden
                            Wim Hompes
                            Wim Hompes
                          • Map colours and side roads
                          • OSM Routing with MRA
                            Pierre c
                            Pierre c
                          • GPX POI Editor
