  4. Increase the number of exported GPX point
gpxroute pointsrouteplanner
16 Posts 8 Posters 7.7k Views 3 Watching
  • lpagani
    lpagani
    lpagani
    wrote on last edited by lpagani
    If the planned route is long, approx. more than 1,000 km, the number of exported GPX points does not allow an easy way to follow the track.
    Is it possible to increase the number of exported points or to set a maximum distance between them?
    As an example, in the figure below are shown the exported GPX points:
    Rob Verhoeff superg Gerard Wullink 3 Replies Last reply
    • lpagani lpagani
      @lpagani You can use 200 waypoints in a route. Isn't that enough for 1000km? That means, in theory, a waypoint every 5km. Often, you need far fewer than that. Or am I misunderstanding your question?
      lpagani 1 Reply Last reply
        lpagani
        lpagani
        lpagani
        @Rob-Verhoeff I mean the raw points exported in the track of GPX file, not the waypoints.
        Rob Verhoeff RetiredWingMan 2 Replies Last reply
        • lpagani lpagani
          superg
          superg
          superg
          @lpagani in the toolkit there is an option (for gold members) to increase and decrease, or do you want something else? c665882e-b91c-497d-b4f6-93fdbb68722c-image.png
          • lpagani lpagani
            @lpagani Do you mean the number of viapoints from MRA that you export? Most devices have a limit on the number of viapoints (the hand symbol) you can include in a route. This varies from device to device.
            • lpagani lpagani
              @lpagani as far as I know there is no way to tell MRA to include more navigation points in a track GPX file. It's my understanding that a track file already contains a huge number of navigation points . Converting a track to a route certainly results in a very large number of waypoints.
              • lpagani
                lpagani
                lpagani
                Thanks to all for your answers. To clarify I'm referring to the track points (the field trkpt in the GPX file), not the route (or shaping or via points).
                Currently I'm creating the route with MRA, export the GPX file and follow the track on OsmAnd, without the navigation function.
                To show what I mean I've exported the GPX of the track with a long route, ~3,000 km (red polyline), and a very short one (black polyline) and I imported both in MRA tracklog.
                Comparing the two files, the red curve has less track points compared to the black one in the same portion of the route (I assume a decimation is done before exporting the file):
                Since I don't use any active navigation following the track is very difficult in cities.
                There is a limit of 30,000 points during a GPX import due to uploading performance reason.
                I am wondering if there is the same limitation during the export and if there is a way to avoid it. 30,000 points seem a small number of points to accurately represent a long route.
                Rob Verhoeff BMcG 2 Replies Last reply
                • lpagani lpagani
                  @lpagani Then I must admit I don't know the answer...
                  • lpagani lpagani
                    Gerard Wullink
                    Gerard Wullink
                    Gerard Wullink
                    @lpagani You show us a map with the Track shown on it That is not a route and you will not receive instructions. You just have to follow the line manually.
                    If you would convert the track to a Route it will use the map to make sure you are using/following roads.
                    The track is normally just a transfer method from one device to another. (Assuming you are not riding offroad).
                    • Gerard Wullink Gerard Wullink
                      lpagani
                      lpagani
                      lpagani
                      @Gerard-Wullink I prefer to follow the track instead of using the navigation although I'm not driving off-road. The track comes from a route planned in MRA, my goal is not to convert the track after exporting it or receive instructions.
                      My question was if it is possible to export the GPX with more track points, because the default number of points is pretty small if the planned route in MRA is long.
                      I've showed the image to show the low resolution of track points in the exported GPX file and the difference between a short and a long route.
                      Gerard Wullink UltraStar 2 Replies Last reply
                      • lpagani lpagani
                        Gerard Wullink
                        Gerard Wullink
                        Gerard Wullink
                        @lpagani No there is no way to set the number of points to export.
                        • lpagani lpagani
                          UltraStar
                          UltraStar
                          UltraStar
                          @lpagani That looks awfully familiar to the routes exported to the Garmin devices. Straight lines between the via points.
                          Bouke Ent 1 Reply Last reply
                          • UltraStar UltraStar
                            Bouke Ent
                            Bouke Ent
                            Bouke Ent
                            #13
                            @UltraStar a track has straight lines between points. only it has many points so when you zoom out ik looks like it follows a road or a path. a track has no connection with a map but is just a list op point with there position.
                            UltraStar 1 Reply Last reply
                            • Bouke Ent Bouke Ent
                              UltraStar
                              UltraStar
                              UltraStar
                              @Bouke-Ent Thank you, I do understand that. Still, the red line (short track outlined by @Ipagani) looks like the route exported to Garmin. There were lot of posts in the past about that and, I am guessing, that issue was resolved.
                              Considering point limit during the GPX import, I can understand longer straight lines.
                              I use MyRoute-app exclusively so I am not an expert in exporting the file. I had Zumo before, and it was too much hassle to transfer, convert, fix the straight lines. I just want to ride.
                              • lpagani lpagani
                                BMcG
                                BMcG
                                BMcG
                                Hi @lpagani
                                Sorry I don't have an ideal solution
                                From your above posts it seems you dont want to use a route or any active navigation intructions, could you advise why you prefer to manually follow the track & not a route?
                                Reason I ask is in Osmand you can take a track & use the "Attach to Roads" feature which will do a similar thing as adding more track points. i.e. it will force the path onto the nearest roads
                                The issue may be for you that this produces a route but you could just follow the route line if you dont start the active navigation which would be similar to following the track line
                                BlackView BV7100, Android 12
                                • BMcG BMcG
                                  Hi @lpagani
                                  lpagani
                                  lpagani
                                  lpagani
                                  #16
                                  @Brian-McG no problem, thanks for the answer anyway. I don't have any practical reason to don't use active navigation, I'm just used to use the passive one while riding. It's a kind of mixture between the paper map and the active navigation.
                                  Attaching the track the road and then create a route or a new track in OsmAnd is possible. This is what I do for short tracks, about two or three days. Unfortunately it doesn't work for long tracks (sometimes it cuts the track in half or it doesn't find a solution at all).
                                  The workaround I found is to split the route in segment of approx 1,500 km, export them to TomTom planner, recreate the route and export the GPX that has way more points than the MRA exporter.
                                  BMcG
                                  BMcG
                                  superg
                                  superg
                                  Bouke Ent
                                  Bouke Ent
                                  Gerard Wullink
                                  Gerard Wullink
                                  UltraStar
                                  UltraStar
                                  lpagani
                                  lpagani
                                    100
                                  • Route exporteren uit beta
                                    77
                                  • Startpunt wijzigen
                                  • V6 - Track Navigation
                                    BMcG
                                    BMcG
                                    Thomas Schäfer
                                    Thomas Schäfer
                                    1.7k
