  4. Increase the number of exported GPX point
gpxroute pointsrouteplanner
16 Posts 8 Posters 7.9k Views 3 Watching
  • lpagani
    lpagani
    lpagani
    wrote on last edited by lpagani
    Thanks to all for your answers. To clarify I'm referring to the track points (the field trkpt in the GPX file), not the route (or shaping or via points).
    Currently I'm creating the route with MRA, export the GPX file and follow the track on OsmAnd, without the navigation function.
    To show what I mean I've exported the GPX of the track with a long route, ~3,000 km (red polyline), and a very short one (black polyline) and I imported both in MRA tracklog.
    Comparing the two files, the red curve has less track points compared to the black one in the same portion of the route (I assume a decimation is done before exporting the file):
    Since I don't use any active navigation following the track is very difficult in cities.
    There is a limit of 30,000 points during a GPX import due to uploading performance reason.
    I am wondering if there is the same limitation during the export and if there is a way to avoid it. 30,000 points seem a small number of points to accurately represent a long route.
    Rob Verhoeff BMcG 2 Replies Last reply
    • lpagani lpagani
      @lpagani Then I must admit I don't know the answer...
      • lpagani lpagani
        If the planned route is long, approx. more than 1,000 km, the number of exported GPX points does not allow an easy way to follow the track.
        Is it possible to increase the number of exported points or to set a maximum distance between them?
        As an example, in the figure below are shown the exported GPX points:
        Gerard Wullink
        Gerard Wullink
        Gerard Wullink
        @lpagani You show us a map with the Track shown on it That is not a route and you will not receive instructions. You just have to follow the line manually.
        If you would convert the track to a Route it will use the map to make sure you are using/following roads.
        The track is normally just a transfer method from one device to another. (Assuming you are not riding offroad).
        lpagani 1 Reply Last reply
        • Gerard Wullink Gerard Wullink
          lpagani
          lpagani
          lpagani
          @Gerard-Wullink I prefer to follow the track instead of using the navigation although I'm not driving off-road. The track comes from a route planned in MRA, my goal is not to convert the track after exporting it or receive instructions.
          My question was if it is possible to export the GPX with more track points, because the default number of points is pretty small if the planned route in MRA is long.
          I've showed the image to show the low resolution of track points in the exported GPX file and the difference between a short and a long route.
          Gerard Wullink UltraStar 2 Replies Last reply
          • lpagani lpagani
            Gerard Wullink
            Gerard Wullink
            Gerard Wullink
            @lpagani No there is no way to set the number of points to export.
            • lpagani lpagani
              UltraStar
              UltraStar
              UltraStar
              @lpagani That looks awfully familiar to the routes exported to the Garmin devices. Straight lines between the via points.
              Bouke Ent 1 Reply Last reply
              • UltraStar UltraStar
                @UltraStar a track has straight lines between points. only it has many points so when you zoom out ik looks like it follows a road or a path. a track has no connection with a map but is just a list op point with there position.
                UltraStar 1 Reply Last reply
                • Bouke Ent Bouke Ent
                  UltraStar
                  UltraStar
                  UltraStar
                  @Bouke-Ent Thank you, I do understand that. Still, the red line (short track outlined by @Ipagani) looks like the route exported to Garmin. There were lot of posts in the past about that and, I am guessing, that issue was resolved.
                  Considering point limit during the GPX import, I can understand longer straight lines.
                  I use MyRoute-app exclusively so I am not an expert in exporting the file. I had Zumo before, and it was too much hassle to transfer, convert, fix the straight lines. I just want to ride.
                  • lpagani lpagani
                    BMcG
                    BMcG
                    BMcG
                    Hi @lpagani
                    Sorry I don't have an ideal solution
                    From your above posts it seems you dont want to use a route or any active navigation intructions, could you advise why you prefer to manually follow the track & not a route?
                    Reason I ask is in Osmand you can take a track & use the "Attach to Roads" feature which will do a similar thing as adding more track points. i.e. it will force the path onto the nearest roads
                    The issue may be for you that this produces a route but you could just follow the route line if you dont start the active navigation which would be similar to following the track line
                    • BMcG BMcG
                      Hi @lpagani
                      lpagani
                      lpagani
                      lpagani
                      @Brian-McG no problem, thanks for the answer anyway. I don't have any practical reason to don't use active navigation, I'm just used to use the passive one while riding. It's a kind of mixture between the paper map and the active navigation.
                      Attaching the track the road and then create a route or a new track in OsmAnd is possible. This is what I do for short tracks, about two or three days. Unfortunately it doesn't work for long tracks (sometimes it cuts the track in half or it doesn't find a solution at all).
                      The workaround I found is to split the route in segment of approx 1,500 km, export them to TomTom planner, recreate the route and export the GPX that has way more points than the MRA exporter.
                      BMcG
                      BMcG
                      Gerard Wullink
                      Gerard Wullink
                      UltraStar
                      UltraStar
                      lpagani
                      lpagani
                      • Sharing live location with friends on Android Auto problem
                      • Ability to hide all waypoints at once after planning?
                        Bé Jeuring
                        Bé Jeuring
                      • Next: Ich brauche Hilfe zu POI und Favoriten!
                      • MRA AI Routeplanner - Improvement
                      • Planner: Convert batches of shaping points into via points and vice versa
                      • How can I change colours in the route overview?
                        Parantapa
                        Parantapa
                      • Weather: rain colors
                      • AI planner: add your favorites
