  3. Joining Rides
Joining Rides
4 Posts 2 Posters 962 Views 1 Watching
  • Andrew Vaughan
    Andrew Vaughan
    Andrew Vaughan
    Hello to everyone .Is there a way you can combine a few routes together to make one ? on my Scenic app it allows you to do this.
    but i now want to only use MRA so just seeing if there is a way . see picture can i put 1.2 and 3 together
    thank you
    Nick Carthew 2 Replies Last reply
    • Andrew Vaughan Andrew Vaughan
      thank you
      @Andrew-Vaughan Yes, this is called Merge and if you type merge into the support search box you will find a support article. Tip: make a copy of the first route and use this to merge the other routes to. This is because the first route or the base route will change.
      Andrew Vaughan 1 Reply Last reply
        thank you
        @Andrew-Vaughan https://www.myrouteapp.com/support
          Andrew Vaughan
          Andrew Vaughan
          Andrew Vaughan
          @Nick-Carthew
          Thank you Nick
          Andrew Vaughan
          Andrew Vaughan
            283
            49
          • waar vind ik de bestaande POI'S
            1.4k
          • Allow the last entered point to be set as a via point
          • Restriction on scenic length?
          • Statistieken
          • Opstarten app in Android.
            Beemerfrankie
            Beemerfrankie
