  4. No speech after less than one minute active
7 Posts 3 Posters 1.3k Views 2 Watching
  • R Vankooij
    R Vankooij
    R Vankooij
    So i have a Iphone 10 and using mra next app. The speech cancelling itself EVERY TIME. So set the speech to on. Nothing. Goto setting and again set the speech on. Then it works and after less than one minute the speech has set itself to off again. Horrible. Its unusable like this.
    What am i missing???
    • R Vankooij R Vankooij
      @R-Vankooij For iOS, this should be quite simple, unless you have various speech settings configured in your iPhone settings. It's possible that one of those settings is conflicting with the app. Within the app itself, you need at least these settings in the audio menu. The name of the voice is just an example. Choose Ellen, Claire, or Xander (I asume you're Dutch spoken refering to your name...):
      • R Vankooij
        R Vankooij
        R Vankooij
        I have everything set to max . Then it works and after a little time everything is set to off again. Dutch yes….
          @R-Vankooij Could it be that there's a specific setting active somewhere in your iOS settings? For example, for a hearing aid or other device that affects sound? I can't think of anything else. It should be rather streight forward!
            Are you using it with a headset in your Helmet and do you have other devices paired with that same headset?
            • R Vankooij
              R Vankooij
              R Vankooij
              I have a Cardo pachtalk bold connected to my phone but that’s it.
                From my experencies with Android devices.
                Other apps can break the connection. Just something simple like a beep from your message app.
                R Vankooij
                R Vankooij
