  3. Hide waypoints when planning?
4 Posts 3 Posters 2.0k Views 1 Watching
  • Michael McMahon
    Michael McMahon
    Michael McMahon
    Hi everyone,
    Is it possible to hide waypoints after creating a route? My current trip has hundreds of waypoints which serve no other purpose than maintaining the route on the correct road. Is there a way to toggle off or hide the way points after I'm done adjusting my route? As it currently is, the map is saturated with routing waypoints and it's difficult to see my favorites and POIs. All I want to see is the line on the road. Google Maps only shows their shaping points when you click on the route, otherwise they're normally hidden.
    • Michael McMahon Michael McMahon
      Hi everyone,
      @Michael-McMahon said in Hide waypoints when planning?:
      Hi everyone,
      Hello @Michael-McMahon. Generally speaking, you shouldn't require hundreds of waypoints to form your route. It is not possible to hide the waypoints, so you could try deleting some to make your route more visible. Alternately, you can use the Route tab on the left of the route editor to add this particular route to an existing one. This will just show a line of your route that cannot be edited. I suggest making a new route (call it display or something) with just 1 waypoint that you can use to display other routes. Open the display route and choose to add the route with hundreds of waypoints. 40c1f397-6fb2-49d3-b394-aa783682de3e-image.png
      An9dy 1 Reply Last reply
        Hi everyone,
        An9dy
        An9dy
        An9dy
        @Nick-Carthew Hi, I also wanted to display routes and toggle-off the waypoints to give a clear uncluttered over view of the route. But when I followed your proposed 'work around', ie adding and merging two routes. As soon as I "merge", the two routes, the waypoints for the added route become visible. - Or am I missing something???
        • An9dy An9dy
          @An9dy said in Hide waypoints when planning?:
          You can’t toggle off the route points.
          My suggestion is to add routes not merge them. This allows you to see the track lines of the added route. It’s useful for seeing daily routes of a tour.
          An9dy
          An9dy
          Michael McMahon
          Michael McMahon
            Marcel Versluis
            Marcel Versluis
            TomOnTour
            TomOnTour
          • Android Auto TFT
          • Route punt overslaan
          • Notche
            Adriaan Vonk
            Adriaan Vonk
