  4. Different and missing information in a PDF vs the web interface
9 Posts 4 Posters 2.8k Views 3 Watching
  • h5jacobsson.us
    h5jacobsson.us
    h5jacobsson.us
    When 'Save as' PDF the resulting pdf has different & missing information. Am I doing something wrong? Or, is it an issue with the software? Please see the pdf file - Missing name in waypoint #17. Also incorrect distances and times starting with waypoint #11. There are more inconsistencies later in the pdf as well.
    • h5jacobsson.us h5jacobsson.us
      @h5jacobsson-us Can't tell you what's happening here. I tried the same with some of my own routes. Pdf's showing the correct info.
      Can you share this route with us? Make sure the route is public before sharing the url.
      h5jacobsson.us 1 Reply Last reply
      • Albert van den Elsen
        Can you share your route with us?
        Make it public and send us the link so we can take a look at it.
        iPhone 15,
        Garmin Zumo XT3
        Carpuride W702 Pro
        Sena 20S EVO headset
        Harley Davidson Road King M8
          h5jacobsson.us
          h5jacobsson.us
          h5jacobsson.us
          @Rob-Verhoeff & @Albert-van-den-Elsen
          Thanks for helping. Here is the whole route - https://www.myrouteapp.com/en/social/route/8786357?mode=share
          Over time I have made a lot of changes to the route. Maybe this has something to do with the errors.
          Rob Verhoeff 2 Replies Last reply
            @h5jacobsson-us On my end, the translation to PDF does exactly the same as with you. I am curious though why you've made it into one route. Why didn't you divide the route into daily stages?
              @h5jacobsson-us A smart comment from @CD130 led us to the following solution: the character set of the website that take care of the translation into a pdf doesn't support the special characters in the street names. If you rename points 17, 26, and 35 to a street name without diacritics, then the translation to the PDF works fine.
              Albert van den Elsen 1 Reply Last reply
                wrote on last edited by Albert van den Elsen
                @Rob-Verhoeff Well found! 👍 This is indeed the solution.
                Just change the special character to a same normal letter! After this change the street name is shown in the PDF.
                e.g. Point 17
                Světlé >> Svetle
                iPhone 15,
                Garmin Zumo XT3
                Carpuride W702 Pro
                • h5jacobsson.us
                  h5jacobsson.us
                  h5jacobsson.us
                  Thank you for your help. Renaming the waypoints did help with the missing items. It didn't help with the incorrect distances though. Up to point 10 it's fine then it becomes incorrect. This to me is a bigger problem than the missing names. If anyone has an idea how to correct it, I would be grateful.
                  As far as it being one route. I will divide the route into dailies, once I have decided the final route. I like to keep it one long route while planning as I find it easier to change and it gives me the total distance and time.
                  BMcG 1 Reply Last reply
                    BMcG
                    BMcG
                    BMcG
                    wrote last edited by
                    @h5jacobsson.us better late than never I suppose!
                    I was looking for an answer to the same question & wondering if it had been reported before
                    the issue with the distances is because point 11 has used the "off road" feature enable to allow for the ferry crossing
                    the distances for the subsequent points are then all out of sequence by 1 point
                    I think this is a bug, hopefully wont be an issue with the new planner
                    BlackView BV7100, Android 12
                    BMcG
                    BMcG
                    h5jacobsson.us
                    h5jacobsson.us
                      390
                      Jack 13
                      Jack 13
                    • Navigatie met DMD tablet
                      Arjan de Vries
                      Arjan de Vries
                    • Myrouteappstay
                    • Real-time traffic
