  4. Different and missing information in a PDF vs the web interface
8 Posts 3 Posters 1.7k Views 2 Watching
  • h5jacobsson.usundefined Offline
    h5jacobsson.us
    When 'Save as' PDF the resulting pdf has different & missing information. Am I doing something wrong? Or, is it an issue with the software? Please see the pdf file - Missing name in waypoint #17. Also incorrect distances and times starting with waypoint #11. There are more inconsistencies later in the pdf as well.
    • h5jacobsson.usundefined h5jacobsson.us
      Rob Verhoeffundefined Online
      @h5jacobsson-us Can't tell you what's happening here. I tried the same with some of my own routes. Pdf's showing the correct info.
      Can you share this route with us? Make sure the route is public before sharing the url.
      h5jacobsson.usundefined 1 Reply Last reply
      • Albert van den Elsenundefined Offline
        Can you share your route with us?
        Make it public and send us the link so we can take a look at it.
        iPhone 15,
        Carpe Iter Tablet V4C
        Sena 20S EVO headset
        Harley Davidson Road King M8
          h5jacobsson.us
          @Rob-Verhoeff & @Albert-van-den-Elsen
          Thanks for helping. Here is the whole route - https://www.myrouteapp.com/en/social/route/8786357?mode=share
          Over time I have made a lot of changes to the route. Maybe this has something to do with the errors.
          Rob Verhoeffundefined 2 Replies Last reply
            @h5jacobsson-us On my end, the translation to PDF does exactly the same as with you. I am curious though why you've made it into one route. Why didn't you divide the route into daily stages?
              @h5jacobsson-us A smart comment from @CD130 led us to the following solution: the character set of the website that take care of the translation into a pdf doesn't support the special characters in the street names. If you rename points 17, 26, and 35 to a street name without diacritics, then the translation to the PDF works fine.
              Albert van den Elsenundefined 1 Reply Last reply
                wrote on last edited by Albert van den Elsen
                @Rob-Verhoeff Well found! 👍 This is indeed the solution.
                Just change the special character to a same normal letter! After this change the street name is shown in the PDF.
                e.g. Point 17
                Světlé >> Svetle
                iPhone 15,
                  h5jacobsson.us
                  Thank you for your help. Renaming the waypoints did help with the missing items. It didn't help with the incorrect distances though. Up to point 10 it's fine then it becomes incorrect. This to me is a bigger problem than the missing names. If anyone has an idea how to correct it, I would be grateful.
                  As far as it being one route. I will divide the route into dailies, once I have decided the final route. I like to keep it one long route while planning as I find it easier to change and it gives me the total distance and time.
                  h5jacobsson.us
                    17
                    238
                    Tom Balmerundefined
                    Tom Balmer
                    John Matthews 0undefined
                    John Matthews 0
                  • Fout in route bibliotheek
                  • Testrit met AA ivm tracklog
                    supergundefined
                  • Moving the map
                    Dave J 0undefined
