  4. Turn Instructions
Turn Instructions
11 Posts 7 Posters 129 Views
  • Vince Hyde
    Vince Hyde
    Vince Hyde
    I just installed the 232 update and started a route and noticed that the GPS map is correct but the instructions in the corner are taken from driving on the left which I haven't noticed in previous versions, this may be a glitch and I will try it on an A to B later.
    Corjan Meijerink Drabslab 2 Replies Last reply
    • Vince Hyde Vince Hyde
      @Vince-Hyde The roundabout exit angle can indeed be incorrect for some roundabouts. Unfortunately it's not consistent and the root cause is with HERE.
      They are working on fixing the issue πŸ™‚
        @Corjan-Meijerink It’s not so much the exit angle that is incorrect it’s the approach to the roundabout that comes from the wrong carriageway that needs fixing. 😊
          Drabslab
          Drabslab
          Drabslab
          @Vince-Hyde
          My god, this is simply dangerous and can lead to serious accidents.
          • richtea999
            It looks like it's applied continental/European routing to a UK route - i.e. it's forcing an anticlockwise rule to the roundabouts.
            Certainly to a European riding/driving in the UK it would be dangerous, agreed. They would take it as a 'normal' direction.
            To a UK resident? - just very weird.
              I see that the routing on the map itself is okay. Is this a result of the version update?
              • richtea999
                @Con-Hennekens It's not solved on the latest build.
                Here's a screenshot from yesterday's ride, using 4.0.6 - 232 on Android:
                The direction is correct - first left at the roundabout - but not by going anti-clockwise!
                It was noted on both Android and iOS (I can't guarantee the iOS version was on the latest beta too, but I believe it was - it's not my device), so it's the routing engine not the app, but I think that was probably already understood.
                The roundabout is here in the UK:
                GL54 5DT
                We were heading south, to then turn east at the roundabout.
                I'm happy to share the route privately, if needed. πŸ•Ά
                • richtea999 richtea999
                  GL54 5DT
                  @richtea999, this defect is very (not) funny... Maybe due to the SDK update. Corjan will understand the priority for this I am sure.
                    GL54 5DT
                    @richtea999 @Con-Hennekens it's indeed an issue with HERE. I've pushed for a solution again today πŸ™‚
                    Lynchy67 1 Reply Last reply
                      Lynchy67
                      Lynchy67
                      Lynchy67
                      I can confirm its also an issue on iOS.
                      Snapshot 31-10-2023 21:44.jpeg
                      • Lynchy67 Lynchy67
                        @Lynchy67 IOS or Android the app uses the same HERE map.
                        Vince Hyde
                        Vince Hyde
                        Drabslab
                        Drabslab
                        Lynchy67
                        Lynchy67
                          Michael 2v
                          Michael 2v
                        • Map Layers
                          Martin White
                          Martin White
