  4. No Voice Instructions
5 Posts 3 Posters 1.6k Views 1 Watching
  • Jurassic Mike
    Jurassic Mike
    Jurassic Mike
    I raised a post some time ago as I was not getting any voice instructions.
    This seemed to resolve itself, I have no idea why as I did not change anything.
    The same happened to me again on Monday in a new route that I had set up. I received no voice instructions at all and in the end I found it impossible to follow the route correctly from the map and had to resort to Waze. No problems with voice instructions there.
    I checked that voice instructions are set correctly by toggling the volume settings and it's fine.
    Any ideas anyone and how can I test it before setting off? when it has worked it has never given me a "ready to go" or any other instruction before I am into the journey.
    • Jurassic Mike Jurassic Mike
      @Jurassic-Mike Strange! Voice guidance should always work if you have set it up correctly in your settings and if it's a route configured with the profiles car, motorcycle, or camper. If you have a route with the route profile walking or cycling, you will never receive voice instructions.
      Jurassic Mike 1 Reply Last reply
        @Jurassic-Mike, I experienced the same thing once. A restart of the route fixed it. I agree it would be great to have the navigation immediately speak something, so you have an immediate possibility to adjust volume too.
          Jurassic Mike
          Jurassic Mike
          Jurassic Mike
          @Con-Hennekens Hi, I did try re-starting the route but it didn't work for me. Thanks for your reply.
            Jurassic Mike
            Jurassic Mike
            Jurassic Mike
            @Rob-Verhoeff yes, it's strange. The route in the Monday case is set up for Car but previously it happened to me for a motorcycle route.
            Jurassic Mike
            Jurassic Mike
