  4. strange error with notes and undo
2 Posts 2 Posters 874 Views
  • martin-phogel.de
    martin-phogel.de
    martin-phogel.de
    I have just discovered a strange error:
    1. create a new route
    2. set a first route point
    3. set a second route point
    4. add a note to the second route point
    5. set a third route point
      (check: the note for the second route point is still present)
    6. select undo (either ctrl+z or the button at the bottom right): route point 3 is removed
    ==> the note for the second route point has also been removed!
    But: go back to route lab and re-open the route: the note to waypoint 2 is present again.
      @Martin-Wilcke interesting!
      martin-phogel.de
      martin-phogel.de
        25
        Vince Hyde
        Vince Hyde
        11.4k
        b0hd1
        b0hd1
      • Probleem met eigen Stay
        Albert van den Elsen
      • POI functie 'strict'
