  4. Statement regarding battery usage
28 Posts 19 Posters 15.4k Views 7 Watching
    I did my first lap with the app today. I use a Samsung S8+, the power comes from a BAAS mini-USB, which only supplies 1A.
    The brightness was permanently set to max, besides MRA I was running the Garmin Drive app (with Bluetooth connection to my Zumo XT) and an app to monitor the battery charge.
    On the MRA app, route navigation and tracking were on all the time. The map settings were Theme=Light, Type=Normal, Building=Off.
    I started with a battery charge of 80%, after two hours the battery was fully charged. So no problems with battery capacity at all.
    Maybe the power consumption depends a lot on the smartphone model?
    @Martin-Wilcke said in Statement regarding battery usage:
    For sure, and probably mainly on the internal graphics engine. It feels like the graphics engine is used 100% whatever settings are used. Less capable graphical logic leads to less problem with drainage. Therefore the problem is likely more eminent on high(er)-end phones.
    • Herko ter Horst Herko ter Horst referenced this topic on
      Hi all! 👋
      As some noticed, the battery usage of the app is quite high.
      This is a known issue since spring and as you might know, the issue is caused by the HERE engine that renders the map.
      I've been on the phone with my local contact @ HERE and they've confirmed the issue and expect an improvement in Q3 2023 (meaning in the next 2 months) 🙂
      We are totally dependent on HERE regarding this issue and hope their planned improvements to resolve the issues you experience.
      Cheers,
      Corjan
      Shawn Graham
      Shawn Graham
      Shawn Graham
      @Corjan-Meijerink this issue appears unresolved. I'm still having an issue.
      How do we fix it. I can't use if battery runs out before I get where I'm going
      • Shawn Graham Shawn Graham
        @Shawn-Graham well that’s correct 🙂
        They have made minor improvements but yet the real fix still needs to be found!
        • TomOnTour
          TomOnTour
          TomOnTour
          Hi @Corjan-Meijerink!
          Many hanks for the update.
          Thomas
          • Chris Thorpe Chris Thorpe referenced this topic on
          • Adventurer86276
            Adventurer86276
            Adventurer86276
            I been using Scenic app and it used HERE maps in Version 3 and did not have any battery drain issues. I tried MRA because Scenic changed to OSM in V4 and currently has too many bugs from the switch. MRA does have a real problem with battery usage, I could easily use Scenic (V3=HERE maps) while running waze and spotify in the background and my phone would be charged to 100% very often by the time I reach stops or even at the end of the ride, I went on a very short ride the other day with MRA and spotify/waze in the background and by the time I got home my battery was at 69%... So a real problem given it's always charging and despite the thread here talking about HERE being the culprit, Scenic did not have this problem. Very unfortunate as I liked MRA but can't use it for long rides because of the very high battery usage.
            Dae 0 MotoCon 2 Replies Last reply
            • Adventurer86276 Adventurer86276
              Dae 0
              Dae 0
              Dae 0
              @Adventurer86276
              This has been my experience comparing Scenic/MRA too.
              2 days ago I used MRA for 5 hours and returned home to a phone battery of 27%. Only 2 weeks ago I did a full week tour of 200+ miles each day (8 hours) using Scenic, and never arrived at a hotel with less that 40% battery. That's 3 hours extra usage but with 13% less battery usage. Yes, I could plug my phone in, but with Scenic I never have to.
              As you say, until the recent move to OSM Scenic was using NEXT. To be fair though, there was a battery drain issue similar to MRA early last year, but the developer fixed it.
              Vince Hyde 1 Reply Last reply
              • Dae 0 Dae 0
                @Adventurer86276
                Vince Hyde
                Vince Hyde
                Vince Hyde
                @Dae-0 I used to have similar issues I use an S21 ultra phone with a Quadlock Wireless Charger and a Packtalk and on a trip at lunchtime I would have to charge the phone with a battery pack as it would be less than 50%, I then started playing music on a spare phone and that helped reduce the drain by about 50%, now with the same phone, cardo and listening to music on the S21 Ultra but charging the phone wired I get 100% all day.
                  @Adventurer86276 said in Statement regarding battery usage:
                  HERE offers multiple developer platforms. Scenic was probably using an older one. The old MRA "previous" app also did not suffer from powerdrain, despite using HERE maps. HERE's own current WeGo app though, suffers from the same powerdrain, and is built upon the same SDK as the Navigation Next app. So, it is not simply by choice of the map-provider, but of the SDKs they offer to developers.
                  Vince Hyde
                  Vince Hyde
                  TomOnTour
                  TomOnTour
                  martin-phogel.de
                  martin-phogel.de
                  Drabslab
                  Drabslab
                  Bart De Medts
                  Bart De Medts
                  Dae 0
                  Dae 0
                  paul69
                  paul69
                  Fred Gilbert
                  Fred Gilbert
                  Lynchy67
                  Lynchy67
                  Adventurer86276
                  Adventurer86276
                  Shawn Graham
                  Shawn Graham
                  Flat Twin Therapy
                  Flat Twin Therapy
                  Herman 1b
                  Herman 1b
                  • Here Terrain maps style
                    Stanisław
                    Stanisław
                    172
                  • Migration of my data
                    Steve Crispin-Brown 0
                    167
                  • MRA AI Routeplanner credits
                    122
                    Bart 9a 0
                    Bart 9a 0
                  • Map layers
                    Stanisław
                    Stanisław
                  • Synchronisatie tussen bèta en classic
                    Henk Nuijens
                    Henk Nuijens
                  • Map viewing options
