  4. Won't route round trip
3 Posts 3 Posters 987 Views 1 Watching
  • Greenham
    Greenham
    Greenham
    I have a small 80 mile loop I ride on my M/C. I downloaded the route from MRA and uploaded on my Honda Gold Wing M/C GPS. Yet when I go to start the route it ENDS at the furthest point in the loop. There is no routing back home.
    Marinus van Deudekom Rob Verhoeff 2 Replies Last reply
    • Greenham Greenham
      @Greenham of you want to use a route like that create it in the web module, then in will work. The generator will only work in de app version and you can't export it to a gps systeem
      • Greenham Greenham
        @Greenham said in Won't route round trip:
        Isn't that completely logical? If you've reached the end of the route and that endpoint is not your home address, then you'll have to initiate a new navigation action. Or am I not understanding your question?
        Greenham
        Greenham
          461
        • Myrouteappstay
        • Track colors by section.
          Rolf Engelsman
          Rolf Engelsman
          Marcel Versluis
          Marcel Versluis
