  3. Viewing Map
Viewing Map
5 Posts 4 Posters 1.1k Views 2 Watching
  • stuart marritt
    stuart marritt
    stuart marritt
    Is there a way to view just the map on a PC without the Create scenic roundtours box permanently showing? and without having to create a route?
    Sometimes when I like to have a look at maps and places before deciding to plan routes
    Also when in Routelab if you click on the map it puts a point on the map and you cannot remove this which is rather annoying
    Nick Carthew Reinhard-32 2 Replies Last reply
    • stuart marritt stuart marritt
      @stuart-marritt said in Viewing Map:
      To remove the route point, click on it to open it and then click the trash can to delete it.
      stuart marritt 1 Reply Last reply
        Reinhard-32
        Reinhard-32
        Reinhard-32
        @stuart-marritt I had the same problems. My solution: create a route, delete all waypoints and you will have an „ empty route“ without any content. When you lock the (non existing) waypoints you can move the map around.
        Kindly regards
        Reinhard
        Montana 700i and Mac
          stuart marritt
          stuart marritt
          stuart marritt
          @Nick-Carthew said in Viewing Map:
          Thanks but that's not an option in routelab
          Stanisław 1 Reply Last reply
            Stanisław
            Stanisław
            Stanisław
            @stuart-marritt There is a possibility to switch on a confirmation for adding new point - there is a question displayed then and you can choose NO. That was the best solution for me.
            Regards
            Staszek
            Stanisław
            Stanisław
            stuart marritt
            stuart marritt
            Reinhard-32
            Reinhard-32
            • Routing issue
            • Live tracking
              465
            • More personalized dashboard
              peha
              peha
