  3. BMW NAVIGATOR 5
BMW NAVIGATOR 5
7 Posts 4 Posters 2.0k Views 1 Watching
  • Nicholas Turner
    Nicholas Turner
    Nicholas Turner
    Hi can any help..When i put the tracks into the sat nav...When i come to use the unit does what it wants it will not follow the track..Is there something in the settings of the unit i need to change at present its set for fastest...Thanks
    TorqueRider paul69 Rob Verhoeff 3 Replies Last reply
    • Nicholas Turner Nicholas Turner
      @Nicholas-Turner
      Have you converted the track to a route in your nav?
      Nicholas Turner 1 Reply Last reply
        paul69
        paul69
        paul69
        This post is deleted!
        • paul69
          paul69
          paul69
          @Nicholas-Turner
          hi @Nicholas-Turner
          I have pointed a few people in the direction of the thread below,
          sometimes when you export a planned route it may not be the same as originally planned. the device in question will change the route, to what it believes is the better route according to your settings. this can be the same when using basecamp.
          until recently when I found out this info, I would be riding a route and think to myself, I am sure I didn't plan to come this way
          MRA have solved this problem in part by using 1.2gpx, I will not try to explain for fear of getting it wrong.
          these threads will help a lot
          https://forum.myrouteapp.com/topic/2734/gpx-1-1-vs-1-2-simple-explanation
          https://forum.myrouteapp.com/topic/2743/1-2-gpx-format-and-the-6-5-garmin-sw/21
          https://forum.myrouteapp.com/topic/2719/gpx-1-1-vs-1-2
          also this forum is very informative,
          https://www.zumouserforums.co.uk
          jfheath does seem very knowledgeable
          once you have read these, things will become a lot more clear, of sorts.
          • TorqueRider TorqueRider
            @Nicholas-Turner
            Nicholas Turner
            Nicholas Turner
            Nicholas Turner
            @Jack-van-Tilburg Hi thanks for getting back to me yes to your question its all converted but the system will not follow the route..
              @Nicholas-Turner No problems here with Nav5. Perhaps change the settings of your Nav5? I allways use: schortest route, no dirt roads, -toll, -seasonal road closures etc.
              In other words, navigate as is.
              • TorqueRider
                @Nicholas-Turner said in BMW NAVIGATOR 5:
                There is one setting important: you need to disable recalculation!
                paul69
                paul69
                Nicholas Turner
                Nicholas Turner
                  John Matthews 0
                  John Matthews 0
