  3. BMW NAVIGATOR 5
BMW NAVIGATOR 5
7 Posts 4 Posters 1.2k Views 1 Watching
  • Nicholas Turnerundefined Offline
    Nicholas Turner
    Hi can any help..When i put the tracks into the sat nav...When i come to use the unit does what it wants it will not follow the track..Is there something in the settings of the unit i need to change at present its set for fastest...Thanks
    Jack van Tilburgundefined paul69undefined Rob Verhoeffundefined 3 Replies Last reply
    • Nicholas Turnerundefined Nicholas Turner
      Jack van Tilburg
      @Nicholas-Turner
      Have you converted the track to a route in your nav?
      Nicholas Turnerundefined 1 Reply Last reply
        paul69undefined Offline
        This post is deleted!
        • paul69undefined Offline
          @Nicholas-Turner
          hi @Nicholas-Turner
          I have pointed a few people in the direction of the thread below,
          sometimes when you export a planned route it may not be the same as originally planned. the device in question will change the route, to what it believes is the better route according to your settings. this can be the same when using basecamp.
          until recently when I found out this info, I would be riding a route and think to myself, I am sure I didn't plan to come this way
          MRA have solved this problem in part by using 1.2gpx, I will not try to explain for fear of getting it wrong.
          these threads will help a lot
          https://forum.myrouteapp.com/topic/2734/gpx-1-1-vs-1-2-simple-explanation
          https://forum.myrouteapp.com/topic/2743/1-2-gpx-format-and-the-6-5-garmin-sw/21
          https://forum.myrouteapp.com/topic/2719/gpx-1-1-vs-1-2
          also this forum is very informative,
          https://www.zumouserforums.co.uk
          jfheath does seem very knowledgeable
          once you have read these, things will become a lot more clear, of sorts.
            @Nicholas-Turner
            Nicholas Turner
            @Jack-van-Tilburg Hi thanks for getting back to me yes to your question its all converted but the system will not follow the route..
              Rob Verhoeffundefined Online
              @Nicholas-Turner No problems here with Nav5. Perhaps change the settings of your Nav5? I allways use: schortest route, no dirt roads, -toll, -seasonal road closures etc.
              In other words, navigate as is.
                Jack van Tilburg
                @Nicholas-Turner said in BMW NAVIGATOR 5:
                There is one setting important: you need to disable recalculation!
                paul69undefined
                Jack van Tilburg
                Nicholas Turner
                  Lenny Oundefined
                  Lenny O
                  277
                • Updated beta! 5.2.1 (486)
                • Veekeersinfo en omleiden
                  marko 11 0undefined
                  marko 11 0
                  422
                • wrong routing
                  John S Parryundefined
                • Play Knop in Route Lab
                  Peter Zehentreiterundefined
                • Geen gesproken aanwijzingen
                  supergundefined
                • Quickly rename route/track in the routes/track-screen
                  Sjoerd Spiekerundefined
                  Sjoerd Spieker
