  3. Garmin XT
Garmin XT
9 Posts 5 Posters 1.8k Views 1 Watching
  • Matthew Perkins 0
    Matthew Perkins 0
    Matthew Perkins 0
    Garmin XT - it seems the MRA suggest you just use MRA created routes as a Track in a Garmin or maybe i just do not fully understand the support page. But i want to converts my track to a route as i want audible instructions... however when i do this my Garmin always changes the route from the track i created.. is there a way around this or do i have something set up wrong on my Garmin Device?
    HABVEN aka MrMRA Steve Lynch 2 Replies Last reply
    • Matthew Perkins 0 Matthew Perkins 0
      @matthew-perkins-0
      Hi Matthew, use gpx1.1 you can use the route you created.
      Before you start the route, make sure that you are on the starting point and that you have connections with minimum off 3 satteliets
      Matthew Perkins 0 1 Reply Last reply
        Steve Lynch
        Steve Lynch
        Steve Lynch
        @matthew-perkins-0
        In my experience with the XT most recalculation issues are caused by not having enough waypoints in your route.
          @matthew-perkins-0
          Matthew Perkins 0
          Matthew Perkins 0
          Matthew Perkins 0
          @hans-van-de-ven-mra-master I do this but it seems to always re-route... do i need to add more waypoints to shape the route more?
          Inge Bakermans 1 Reply Last reply
          • Steve Lynch Steve Lynch
            @matthew-perkins-0
            Matthew Perkins 0
            Matthew Perkins 0
            Matthew Perkins 0
            @steve-lynch Thanks
              Inge Bakermans
              Inge Bakermans
              Inge Bakermans
              @matthew-perkins-0 Make sure you have every 5/6km (3/4 miles) a waypoint. Should keep the XT from recalculation.
              • Inge Bakermans Inge Bakermans
                Matthew Perkins 0
                Matthew Perkins 0
                Matthew Perkins 0
                @inge-bakermans Thank You
                Chris Hoskins 1 Reply Last reply
                  Chris Hoskins
                  Chris Hoskins
                  Chris Hoskins
                  wrote on last edited by Chris Hoskins
                  @matthew-perkins-0
                  I have found that creating a waypoint maybe half a mile (KM) after each major junction will keep you on the right route. Always put a waypoint a mile down the road from your starting position and use this as the first waypoint. If you don't the sat nav can keep trying to reroute you back to the start if you weren't close enough.
                  I wouldn't say you need a waypoint every 3/4 miles though, especially if you are on a main road. It's the small goat tracks the sat Nav suggests to save you 500 yards that you have to learn to ignore!
                  I always use plenty of waypoints around towns and after major junctions.
                  However the 'skip waypoint' feature is still often required on my Garmin XT!
                  • Chris Hoskins Chris Hoskins
                    @matthew-perkins-0
                    Steve Lynch
                    Steve Lynch
                    Steve Lynch
                    @chris-hoskins
                    Some of us love those Goat Tracks 😳
                    Inge Bakermans
                    Inge Bakermans
                    Matthew Perkins 0
                    Matthew Perkins 0
                    Steve Lynch
                    Steve Lynch
                    Chris Hoskins
                    Chris Hoskins
                    • Hello everyone
                    • Route changed?
                    • Hoe lang moet je abo hebbes voor toegang??
                      Herman Veldhuizen
                      Herman Veldhuizen
                    • Beurs aanbieding
                    • Wissel Here-TomTom
                    • Hoe lang gebruiker
                    • Hello from Thailand
