  4. How to navigate a track?
28 Posts 8 Posters 8.1k Views 4 Watching
  • Guzzist Guzzist
    I blieve, we have the same understanding, but may using other words to explain - or translation does it not in best sense.
    MRA does it in it's own way and sepereates data in stricktly separated areas:
    • Tracklogs - which sould collect only own logged travels (as tracks)
    • Routes - which collects own or received routes and received tracks (here called Route-Tracks)
    • POI - which collects Points of Interests (in gpx standard named as <wpt>
    For the moment, I will not discuss this.
    But I'm asking towards development: based on given build in MRA - if a gpx is going to be imported (which contains a route <rte> and <wpt>. Can we get a solution:
    • to import in one hit the <rte> into the area "Routes" (as route) - and the <wpt> into the area "Routes" / Section "Point of Interest" / tab "Manage"?
    • to Import in one hit the <trk> into area "Routes" (as Route-Track) - and the <wpt> into the area "Routes" / Section "Point of Interest" / tab "Manage"?
    But yes, I see: this will change a paradigma in MRA, because until now Route-Tracks can't have Points of Interest.
    And I consider: what if a gpx file does contain both <rte> and <trk> - and if there are also <wpt> in?
    I believe we need 2 import actions: one for Route and another for Route-Track. Or it could be automated, to get both in one hit - because this is the case in current MRA build if there are 2 routes or 2 tracks in one gpx file to be imported (it creates that separated).
    And I also consider: in this case, a gpx file does contain <rte> and <trk> and <wpt>. To which one sould be the imported <wpt> belong to? To the Route, to the Route-Track, or to both?
    I prefer to both, because if to one of them it's not necessary to get the <wpt> - it's more easy to delete them (one by one), as to enter them (one by one) with search of position afterwards.
    Yes, other Apps can show more than one track in the same map; MRA doesn't. But I think, there is no need to change this in MRA also.
    I can imagine, this would not be a big effort, but a "masterpiece" - which resolves the problems we are discussing here and makes many users happy. And brings MRA again a step vorward in relation to DMD 😉
    I know, many users are there, who will love it - but the "louder" ones are those with Carplay issues...
    Bay the way: DMD does also exactly was gpx standard is: showing groupwise content of a a gpx file. All routes <rte>, all tracks <trk>, all waypoints <wpt>. But they don't belong to each other; they are only in one file.
    The only belongings are trackpoints <trkpt> which belongs to tracks <trk>.
    And routepoints <rtept> which belongs to <rte>.
    (see attached images)
    martin-phogel.de
    martin-phogel.de
    martin-phogel.de
    @Guzzist
    I understand and agree with all the facts and details you pointed out.
    Just one more question: I mentioned the TET S GPX file in the other thread, which contains 21 <trk> and 760 <wpt>.
    What is your preferred solution here: creating 21 route-tracks and inserting 760 POIs in the "POI / manage" tab for each of the 21 route-tracks?
    Guzzist 1 Reply Last reply
      @Guzzist
      @Martin-Wilcke do you intend to drive all that TET sections in one ride? That will last 2-3 Months...
      My longest rides to Morocco and round Italy lasts each 5 Weeks. I splitted the routes in parts - one for each rinding day.
      In your case, I would import the gpx to get all <wpt> as Point of Interest. Then I would import the gpx again to get the tracks. If all the sections are in one gpx, you will get one object (Route-Track) for each section.
      Then open one of the Route-Tracks and select in the options "rework the track" - this will convert it to a route. Now in this Route, you can go to Waypoints and activate in Tab "Bibliothek" your before imported POI list. This will populate all POIs in the route (you will see it only in a lower zoom level).
      If you then open MRA Navigation App, open one of these routes to navigate, then you will also see all that POI. Before, you need to have activated synchronisation between MRA-Navigation with MRA-Roueplanner.
      Nothing is impossible ;-)
      • Bouke Ent
        Bouke Ent
        Bouke Ent
        my use is otherway arround. i make route in MRA planner. if it is an option in the Here map. If Here does not want to make a route and OSM wants then i switch to OSM map. I make my route and if it is done i will add Poi. If done i make a gpx track and poi. now i download gpx and upload it to other app that support OSM maps or convert a track to be able to navigate. OSMAND and Bmaps (dutch app on android) are my most use. both show track and poi on the screen. MRA Next is perfect for road or path that Here knows. but in some part OSM maps are giving more road. I am not a offroad biker.... just like to ride small backroads, farmroad of gravelpasses. my option now is to use 2 phone. 1 with MRA Next for the parts that Here knows and 1 for showing the track.
        • Bouke Ent Bouke Ent
          @Bouke-Ent I understand your point, because I'm doing the same - but I think, a bit more elegant. I don't use 2 devices, but only one: T-865X from DMD. They offer also smaller devices and the possible best app for navigating tracks - DMD2. Devices and app are manufactured from riders for riders.
          The devices are based on Android, therefore you can install additional apps to the DMD2 app.
          Because I'm riding also offroad as well as onroad, I use the probably best app for onroad: MyRoute-App. And parallel for offroad the DMD2 app, LocusMap and OsmAnd. Just that app, which is the best for current situation.
          For me the best: driven by the same gpx fike, I can run all apps parallel. Just by push one hardware button, I can switch through all apps - backwards and forwards.
          • Bouke Ent
            Bouke Ent
            Bouke Ent
            my budget is not so big to buy a dmd. i use cheap android phone without sim for showing the track. for me bmaps is a nice small app that looks like the old kurviger pro v1. when i want more detail i have also older osmand with more info/details. bmaps reads the track and wpt.....
            it would be nice to have it all in MRA Next....
            i am allready happy with show track on freeride mode.
            again thanks to point this to me in this topic.
            b0hd1 1 Reply Last reply
              b0hd1
              b0hd1
              b0hd1
              @Bouke-Ent There are many other alternatives to the DMD2, which in my opinion are overrated and overpriced. On the other hand, all manufacturers are focusing on CarPlay/Android Auto, both in cars and motorcycles. There's no going back. It's not the future anymore, it's the present. Your option of a simple smartphone is just as valid as any DMD2 product. And I'm not just saying this based on hearsay; I'm speaking from personal experience (I bought a DMD1 when nobody knew about it yet...). Cheers!
              • https://t.me/MRa_by_b0hd1
              • YouTube: @demco17
              • Guzzist Guzzist
                I'm a bit confused and wonder if development was running in a strange direction with "navigate route as track"...?
                I know the sense of this, but my intention is, to get a gpx file which contains a track only and navigate by this.
                If I import such a file as Track or as Route-Track - the result is always the same - no matter which preferences I select: I get always a blue and a white line, if I start navigation with. That's annoying! I know, I should follow in this case the white line. But this forces unnecessary extra concentration!
                The only mitigation I found is: select this Track or Route-Track for navigation, but start as "free ride"! Result: you will get only a blue line and you can navigate by clearly following the line (as usually for track navigation).
                Same issue is reported by @Martin Wilcke https://forum.myrouteapp.com/post/75062
                Second issue: if gpx files contains waypoints <wpt> (POI), the import procedure operates that like stepchilds!
                In case, gpx is imported as track, this points will never be imported!
                In case, gpx is imported as Route-Track, this points will never be imported!
                In case, gpx is imported as Route, this points will be imported as shaping points!
                But why? The export procedure does it correctly.
                wrote on last edited by BertM
                #27
                @Guzzist said in How to navigate a track?:
                I fully agree, but I think it has to do with the database structure (I believe POI is added later??)
                the fully exported GPX file (route-track-POI) from MRA wil also not be the same when imported again in MRA
                Bouke Ent 1 Reply Last reply
                • BertM BertM
                  Bouke Ent
                  Bouke Ent
                  Bouke Ent
                  @BertM said in How to navigate a track?:
                  i have same problem, but then i only focus on track and poi. track can be imported from gpx file but poi (wpt) are not.
                  i get comments that i want to change subject but this is in my case the point. wpt are not imported from gpx file if import is only based on track.
                  other ways i did not look at.
                  b0hd1
                  b0hd1
                  martin-phogel.de
                  martin-phogel.de
                  Bouke Ent
                  Bouke Ent
                  Paul Smith 3
                  Paul Smith 3
                  • Routing issue
                  • Live tracking
                    451
                  • More personalized dashboard
