  4. Routing Settings only partially visible.
2 Posts 2 Posters 525 Views 2 Watching
  • Keith Warrington
    Keith Warrington
    Keith Warrington
    On the app, I only get to see the "Routing settings" if I select a route
    IF I select a destination, say parking restaurant etc.. after using the search function.... then the "Routing settings" cannot be seen on the screen below the map.
    Thanks in advance - Keith (St. Albans UK)
      Probably because the routing settings aren't available - most likely because you've selected "motor" as transport mode.
      The routes you load are maybe created for "car" and have routing settings.
      Keith Warrington
      Keith Warrington
      • F014 WP Numbering illogical
      • Map colours and side roads
      • GPX POI Editor
        RainerT
        RainerT
        Adrian Avram
        Adrian Avram
      • OSM Routing with MRA
