  3. Transfer from MRA to ZUMO XT, working from MacBook
24 Posts 8 Posters 11.1k Views 4 Watching
  • TorqueRider TorqueRider
    @Reinhard-32 said in Transfer from MRA to ZUMO XT, working from MacBook:
    I think, some work ist to do with the connection app to work with ZumoXT and the Apple Computers.
    On Apple Mac there is only limited support for MTP devices.
    Therefore, I would suggest investigating whether the connection app can connect to Garmin Drive.
    But on the other hand; I don't have XT and I don't know if that is the best solution now.
    #14
    @Jack-van-Tilburg For me it is not a problem. I use primarily my IPad and the Garmin Drive App.
    So I save the route as GPX file and send it via Drive app to my ZumoXT or I use my Windows computer.
    But the problem has to be solved anyway.
    Kindly regards
    Reinhard
    Montana 700i and Mac
    • TorqueRider
      Garmin Drive
      I think the Zumo XT was developed by Garmin for use with Garmin Drive. That's why I think the MRA developers should focus on that if they want to solve the problem.
      In any case, it would help a lot if MRA now writes a knowledge article about the application of the XT in combination with Apple Mac.
      Your clues from this and the other topic can contribute nicely to this.
      • PAD 0
        PAD 0
        PAD 0
        wrote on last edited by PAD 0
        For what it’s worth, here’s something lifted from a Garmin webpage:
        Transferring GPX Files From Your Computer
        Apple computers may require additional third-party software, such as Android File Transfer, to read and write files on this device.
        If you have already created routes that you want to use on your device, you can transfer GPX files directly from your computer.
        Connect the device to your computer (Connecting the Device to Your Computer).
        The device appears as a portable device.
        On your computer, open the file browser.
        Select a GPX file.
        Select Edit > Copy.
        Browse to the GPX folder on the device.
        Select Edit > Paste.
        It seems that thinking in terms of MTP in relation to Apple is a bit pointless as that is a Microsoft protocol and the reference to Android Transfer Protocol (AFT) in the above suggests that the XT is Android based. For Garmin to go down such a route seems bizarre to me, and only bound to invite potential conflicts left, right and centre. Given that both Microsoft and Apple desktops and laptops are essentially ‘universal computers’, each capable of running Windows or macOS with relatively little fuss, to have adopted Android seems a major faux pas in terms of inter-operability. Google have even made a clusterwhatnot out of that between their own ChromeOS and Android! (I suspect short term ‘bottom line’ considerations on the part of bean counters have come into play all round, to the detriment of such worthless things as versatility, flexibility and creativity🥴.)
        It appears quite possible to achieve mac/XT communication at drive level, but only via one application at a time? In which case, installing AFT and making sure any conflicting application or service is stopped before use might be the way to go here (with heavy emphasis on the stopping of those other apps & services)?
        Out of curiosity, I have got myself looking at an issue that doesn’t affect me at all, and is very unlikely to (I probably need to get out more!) Personally, I think the dedicated sat nav has a rather limited future and my current Zūmo 390 will very likely be my last. Spend the money on tyres and petrol I say!
        • HABVEN aka MrMRA
          I think the problem is that an Apple doesn't recognize the Zumo XT
          • PAD 0
            PAD 0
            PAD 0
            Even with Android File Transfer installed?
              I don't have a XT. But understand from various reports that communication with the Apple Mac is not without problems.
              The Zumo XT uses the MTP protocol for communication with a computer. This means that the options on a Mac are somewhat more limited. Only one program can communicate with the Zumo XT at a time.
              Furthermore, Apple does not support the MTP protocol in Finder. So if you want to see the files on your Zumo, you will have to do this with a separate program. For example Android File Transfer. In all cases, other programs may not occupy the Zumo.
              Hi @PAD-0
              Android File Transfer should do the job 🙂
              @Jack-van-Tilburg said in Transfer from MRA to ZUMO XT, working from MacBook:
              • Rene Guiaux
                Rene Guiaux
                Rene Guiaux
                wrote on last edited by Rene Guiaux
                #20
                I have managed to get my route/track/POI to the ZUMO XT in the following steps:
                1. design your route in MRA on the MacBook and save it.
                2. When it is saved the route will be in your archive
                3. take the device (iPhone or IPad) which is connected with your ZUMO XT using GARMIN Drive
                4. If no device is connected, you first have to arrange this. You have to choose to connect your iPhone or your iPad.
                5. If connection is made and the ZUMO XT is switched on you can transfer route/tracks/POI with IPhone of iPad with the MRA app
                6. Open the MRA app on the Iphone or iPad
                7. Go to MyRoutes
                8. Open the route you want to upload to the ZUMO XT
                9. push on 'Page menu' in the top right corner
                10. Select 'save as'
                11. I always choose then .gpx 1.1 (track, POI)
                12. Choose in the following pop up menu the option 'GARMIN Drive'
                13. Now the selected route/track will be uploaded to the ZUMO XT
                14. If you have uploaded the track to the ZUMO XT, now let the ZUMO XT calculate your route.
                15. Make sure recalculation is switched off in the ZUMO XT
                This should do the trick.
                Gr.... Rene
                • Albert Renting Albert Renting
                  @Reinhard-32
                  I've tried this and it seems to work!
                  I have to place these .gpx files in a directory where I can find them with the (in Dutch) 'bestanden' app and then I can send them to the Drive app and then that app will send the .gpx files to my ZUMO XT.
                  Thanks for the tip!
                  Steve Lynch
                  Steve Lynch
                  Steve Lynch
                  @Albert-Renting said in Transfer from MRA to ZUMO XT, working from MacBook:
                  @Reinhard-32
                  Thanks for the tip!
                  If the above means you are using an iPad then use the Chrome Browser.
                  This will allow you to simply download the GPX Beta XT file and then once it it downloaded it will automatically give you the “Open In” prompt where you can select the Garmin Drive App.
                  If the Drive App is not showing the first time you do this select “More” and choose the Drive App.
                  It will then always be available.
                  Safari will force you to save the file to a location and will not give you the prompt to “Open In”.
                  Therefore you have to go looking for the file.
                  Albert Renting 1 Reply Last reply
                  • Steve Lynch Steve Lynch
                    @Reinhard-32
                    Thanks for the tip!
                    Albert Renting
                    Albert Renting
                    Albert Renting
                    @Steve-Lynch Thanks, but I'm not using an iPad, I'm using a MacBook and an iPhone to transfer the gpx file to my Garmin XT
                    Alas, this Garmin Drive App is only available for iPhone and iPad 😞
                    Chris Hoskins Steve Lynch 2 Replies Last reply
                      Chris Hoskins
                      Chris Hoskins
                      Chris Hoskins
                      Likewise I was having issues with transferring routes from my iMac to my Zumo XT.
                      Option One:
                      Copying and pasting the .gpx file using Android file transfer didn't work for me, the Zumo didn't report a new route being imported or show it in my saved routes. (Perhaps you have to put this route in a specific folder?)
                      Option Two:
                      Use the Export function, failed, got the following error:
                      "Device could not be found or written to. Please confirm that the device is actually connected and working properly"
                      It was and is, but didn't transfer!
                      Option Three:
                      Save as as .gpx 1.0 (track. POI), find saved .gpx file, email to myself, open email on iPhone, Send to Garmin Drive, Open Zumo XT, import new track, convert track to route.
                      This works but when you go to access the route it says "Editing this trip will discard the current route settings and calculate a standard route"
                      It seems to give you a good route but it's lost the waypoints, however it is an accurate route.
                      Option Four:
                      Export as .gpx 1.0 (route, track, POI), (Then follow the same procedure of email to yourself, Garmin Drive etc) when imported it recalculates the route but does seem to retain the route chosen and the waypoints.
                      Question:
                      If I change waypoints to shaping points will it still 'force the Zumo to pick a route I've plotted (as long as I add enough points)?
                      Note: I also tried taking it back into Basecamp and transferring to the Zumo but this gave me weird and crazy routes. I think this might have been a mismatch between the maps as I've just been able to transfer the map to my iMac. This ability had been missing until recently from Garmin Express.
                        Steve Lynch
                        Steve Lynch
                        Steve Lynch
                        #24
                        @Albert-Renting
                        In theory you could use MRA Web on Chrome on the iPhone and the Garmin Drive App on your iPhone to do the transfer using the GPX1.1 (BETA Route, Track, POI)
                        Plan on the MacBook, switch to the iPhone to do the transfer.
                        Use the Chrome Browser as Safari will not give you the “Open In” option for the GPX file and will force you to “Save to Files”.
                        If you need to create a collection on the XT you have to do it using the Explore Website not the Explore App and you must also have the Garmin Drive App open as well.
                        Then on the XT if you “Sync” using Explore the collection you created on explore.garmin.com will pull into the XT.
                        Why we can’t just create a Collection directly on the XT is ridiculous. 🤨
                        Albert Renting
                        Albert Renting
                        Steve Lynch
                        Steve Lynch
                        Chris Hoskins
                        Chris Hoskins
                        PAD 0
                        PAD 0
                        Rene Guiaux
                        Rene Guiaux
                          Nick Elsom 0
                          Nick Elsom 0
                        • MRA AI Routeplanner - Improvement
                        • 0 van 15 klaar
                          Mark Vroomen
                          Mark Vroomen
                        • File types for download route
                        • Weather: rain colors
