  4. Beta Planner - What "Exactly" Happens to My Existing Routes
3 Posts 2 Posters 25 Views 1 Watching
  • BMcG
    BMcG
    BMcG
    wrote last edited by
    If I were to subscribe to the web planner beta what exactly would happen to my existing routes?
    I believe there is some kind of transfer from the classic web planner to the beta planner but unsure of the details
    Does my whole classic existing library of routes get transferred to the beta?
    Do my existing routes get removed / deleted from my classic library?
    Do I end up with 2 completely independent copies of the route, one in the classic planner & one in the beta planner?
    If I create a route in the beta planner with the usual informative detail with Via points, coffee, lunch, viewpoints notes & fuel stops with icons etc, I believe this is only visible to other beta participants I share it with within the beta
    Is there a way to sort of reverse transfer a lovely detailed beta planner route back to the classic planner so that it can be shared with existing friends & groups? (I dont want to loose the detail so gpx is NOT an option)
    • BMcG BMcG
      Yes they do
      No they don't
      Yes you will and you can edit the one in the Beta without changing anything to the one in the classic version
      Correct for the time that the Beta has not gone public, so after 15 february it will be for everyone
      If you intention is to share that route with someone not having the Beta option at this time, you could export the route in Beta using the 1.1 format to share it with your non Beta friends. I'm not 100% certain if alle the wonderfull details will be included in that export.
      BMcG 1 Reply Last reply
        Yes they do
        No they don't
        BMcG
        BMcG
        BMcG
        @Marinus-van-Deudekom thanks for the comprehensive reply
        it does raise the question for me what happens in February if I have the same routes in 2 libraries .i.e. the original route in the classic library & the new copy in the beta library
        do I end up with 2 copies of the same route after the 15th February or is the system going to be smart enough to recognise they are identical & only leave 1 copy?
        if i edit both routes before 15th february i.e. the one in the classic library & the one in the beta so the routes are slightly different but the names of the routes are the same what happens?
        BMcG
        BMcG
        • Move a GPS point on the map
          BMcG
          BMcG
          MartinW
          MartinW
        • Stopover expiration time notification
        • MyRouteApp on the Tracer 9 GT+ Display. Works! :)
