Show on the maps's button
Hi,
I’m not sure what this button is for—thanks for your help.PS: Is there a PDF guide available for V6?
Thanks
Hi,
Thanks
@Corrado-Miniati This will display a track of this route on the screen.
You can start a second route at the same time and then view both.
Here's another example.
If you want to follow a route, you have the option to extend the route from a specific point.This way, you'll see alternative route options during navigation and can change your mind along the way.
Thanks Peter, I need to test it for a bit longer; I saw that it adds a tracklog, but I need to figure out how to use it.
In any case, it adds a tracklog, not routes with waypoints, right? -
In any case, it adds a tracklog, not routes with waypoints, right?In any case, it adds a tracklog, not routes with waypoints, right?
correct
Thanks a lot
