Drive app fails to send GPX file - again...
Try opening a second iteration of the Drive app and then get rid of the first. Then the send to device dialog should appear. I reported this issue (looks like a refresh issue to me?) after Garmin broke the Android Version Prior to 4.29.28. I was asked to send further details but didn't. The Garmin bod said it could not possibly happen.......but I sent screen shots.
The older v4.28.14 works
How do you select an older version of the drive app?
Everyone is having problems since the Drive app was updated. On my old SE10 iphone I am still running v4.23.32 without any issues.
Same with the Tread app. There the problems start when your route contains more than 60 routepoints (start and end included).@Guzt I've been through this before. I recently turned off automatic updates in the Google Play Store, so I hope to permanently stay on V4.29.25. Although my first choice might be to use a USB cable and the MRA Connector application.
So you have to pay for a subscription to TotalAV in order to get an older version of Garmin Drive?
Voor android kan je deze gebruiken
If you use an android phone, you can use this one to install an older version
https://garmin-drive.en.uptodown.com/android/versions -
On the evening of Thursday 12 November, Garmin released an update for Garmin Drive in the App Store, and the app is now working again. Check the Apple App Store and download version 4.29.36 of the app.
Op donderdagavond 12 november heeft Garmin een update voor Garmin Drive uitgebracht in de App Store, en de app werkt nu weer. Kijk in de Apple App Store en download versie 4.29.36 van de app.
Thanks for pointing that out; I’ve installed it and it’s working as it used to.
